Author Topic: CB550 Clutch question  (Read 947 times)
Offline arncruz
  • 1977 cb550
« on: September 22, 2014, 11:21:54 AM »
I had recently changed the clutch springs and plates.  I reinstalled the basket and put everything back on the motor.  I  tried the hand control for the clutch and it seems stiff.  I also was able to shift gears without using the clutch.  Any advice would be appreciated.  Thanks in advance
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #43xx survivor
1969 CB750 #12xxx
1970 CB750 K0 survivor
2014 MVP Agusta 675 F3
Offline Bodi
Re: CB550 Clutch question
« Reply #1 on: September 22, 2014, 12:25:06 PM »
One can generally change gears without the clutch with some strain on the transmission.
New springs can increase clutch pull, of course. Presumably they were changed because they had weakened/shortened.
Is the clutch slipping? Does it release properly? Did you readjust the clutch ramp to suit the new plates? Did you re-route the cable - this can make for an unbearable clutch pull?
Offline strynboen
« Reply #2 on: September 22, 2014, 12:30:49 PM »
the chluch rod and push plate can only be mounted at 2 posisions..there are a  set of dots to be" crossing over" to mount it korrekt..oderveise it can not be pressed korrekt inn..it fits not together..and bloks..
i hate all this v-w.... vords
Offline arncruz
  • 1977 cb550
« Reply #3 on: September 22, 2014, 01:03:12 PM »
So i bought this new set of clutch springs which were slightly thicker than the original once.  I tightened them down till the plate was tight onto the 4 protrusions in the clutch basket.  when I connected the clutch cable, the clutch compressed but stiff.  i was worried I was going to break something.  I'm wondering if the increased thickness of the springs had something to do with it.  I'm thinking of putting the original ones back.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
