Author Topic: Cleaning the engine cb750 1978  (Read 3405 times)
Offline briancwynn
  • If created then it is for a purpose!
« on: October 03, 2014, 07:59:09 PM »
All, cleaning the engine and getting stuck on the fins. How do you clean them enough to paint them? Grease seems like it cannot be cleaned out! I am not taking the engine apart.
Honda CB750 1978 K
Stock Carbs w/ Pods
125 main jets, stock slow, and 2 shims on the needle (equal to about raising it one clip)
M-unit
Bike broken down to bare bones and slowly put back together (except for the engine)
Offline skyline223
    • willtuckermusic.com
Re: Cleaning the engine cb750 1978
« Reply #1 on: October 03, 2014, 10:36:23 PM »
I used acetone and Q-tips. Can be time consuming but worth the effort.
Will Tucker
willtuckermusic.com
Offline Vinhead1957
« Reply #2 on: October 04, 2014, 04:56:26 AM »
Gunk has a foam cleaner spray on hose off
« Reply #3 on: October 04, 2014, 08:47:00 AM »
Gunk has a foam cleaner spray...
....and a wire brush is how I did mine.  And clean clean clean before you prime.
Offline RSchaefer
« Reply #4 on: October 04, 2014, 11:58:40 AM »
I soda blasted mine and painted.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline briancwynn
« Reply #5 on: October 06, 2014, 07:33:48 AM »
Qtip and acetone worked.. I thought maybe you were joking like a left handed can opener. It works!  Thanks alk
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
« Reply #6 on: October 06, 2014, 09:02:58 AM »
ZEP Purple Commercial cleaner/de-greaser. 50/50 w/ water in a spray bottle.
an assortment of plastic bristled brushes.  long and short, to get in all the small spots.
rinse with water and then wipe down with acetone.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: October 06, 2014, 09:14:14 AM »
Toothbrushes and your favourite degreaser!
--Evan
1975 CB750K "Rhonda"
Offline rb550four
« Reply #8 on: October 06, 2014, 03:59:25 PM »
I like paint thinner and brass/ stainless brushes, cuts the crud instantly , brushes clean the paint off. Rinse with paint thinner,  shoot  with compressed air. All clean.
Offline Guido56
« Reply #9 on: October 07, 2014, 05:13:12 AM »
Steel brushes for weapons and solvent
I'm sorry but I do not have pictures of when I did I
This, however, 'was the result
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
Offline evanphi
  • Apparently I'm an
« Reply #10 on: October 07, 2014, 05:43:41 AM »
Great idea and excellent results!
Go buy a .30 cal cleaning kit, some solvent, and get to brushing!
--Evan
Offline briancwynn
« Reply #11 on: October 07, 2014, 06:41:53 AM »
Guido what did you put in the carb holes when painting? Did you ball up paper or something or simply cover the holes with tape?
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
« Reply #12 on: October 07, 2014, 07:45:05 AM »
Just mask it well with tape.  Ball up a paper towel first if you're worried.
Offline Guido56
« Reply #13 on: October 07, 2014, 11:56:51 AM »
Attention, steel brushes, not copper or brass, those leave a layer of material not paintable.
And if you are lazy you can apply to a variable speed drill. get ruined but cost little
The collectors were filled with paper and secured with tape to the bodywork.
Sorry for my English but I'm using the google translator
However, if I can be of help, I'm here
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
