Author Topic: CB750F USA 1978 gear box sprocket  (Read 546 times)
Offline Flat out
« on: November 04, 2014, 01:42:49 PM »
We (son paid I repair) have just bought a CB750F USA import. Renewed chain and sprockets but gearbox sprocket differs from the details in the manual. We have a single centre bolt and replacement from David Silver is the same but manual shows 2 bolts. Has mind been modified. Which is correct and what securing arrangement should the single bolt style have?
I am a newbe to the forum but congrats as it is great.
Re: CB750F USA 1978 gear box sprocket
« Reply #1 on: November 04, 2014, 01:46:17 PM »
Welcome!
The early models used two bolts, yours is 1975 - 1978 I assume since thats when SuperSports were made and it uses single bolt.
There is a difference in the output shaft on early models, let me dig out some schema for you.
Offline lucky
« Reply #2 on: November 04, 2014, 01:48:16 PM »
The 1977 CB750K and 78's had a single bolt in the end of the shaft.
Some years had two bolts and a plate. It does the same job.
« Reply #3 on: November 04, 2014, 01:51:33 PM »
Offline Flat out
« Reply #4 on: November 04, 2014, 10:28:15 PM »
70CB750 you are a life saver. Second schematic is exactly what we have. So much appreciate your support
« Reply #5 on: November 05, 2014, 03:11:30 AM »
My pleasure  ;D - just tools of the trade.
Here you can find your model:
http://www.cmsnl.com/honda-cb750four_model14344/
if you ever need more schematics.
