Author Topic: 750F Rear Brake caliper ? W/ Pics  (Read 3101 times)
Offline 78 k550
« on: October 10, 2006, 09:55:36 AM »
Hey All,
I was just starting to go through things i might not be needing. I was looking at this 76 swing arm rod support, and caliper. I say hey this thing has a double piston caliper. Cool. I go look at the one installed on the bike allready. It is only a single piston. Whats up with that. The bike im putting to gether is a 76 750F with a 77 parts bike. I'm running the comstars. and the 77 swing arm and caliper. Did someone do an upgrade on the 75 I got from the junk yard?
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
Re: 750F Rear Brake caliper ? W/ Pics
« Reply #1 on: October 10, 2006, 10:46:29 AM »
I would like to use the double piston if I can. I'm going to be cleanin out the back area so I ca work on them this winter. I should know soon.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline MrZxp
« Reply #2 on: October 10, 2006, 10:54:58 AM »
As far as I am aware the F0 ('75) came standard with the dual piston caliper... not sure why Honda switched to the single piston in later "F" models. Perhaps someone else has an explanation?
Cheers, Phil
09 Boulevard M90
SOHC4 Member #3336
Offline 78 k550
« Reply #3 on: October 10, 2006, 11:34:02 AM »
wonder why that was.
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Gabus
« Reply #4 on: October 10, 2006, 11:57:26 AM »
Honda did change to single piston, some people say that the 2 piston caliper was too powerfull. Don't remember if the switch was F1 or F2
« Reply #5 on: October 10, 2006, 12:36:17 PM »
Paul,
That bad boy ain't no 75 or 76F rear caliper. If you need a pix of mine I can send later.
Jerry
Offline cben750f0
« Reply #6 on: October 10, 2006, 01:56:09 PM »
the caliper on your bike isnt an F1..... i have one and its a dual piston jobby... ??? hope that helps a little ...
peace
Offline kghost
« Reply #7 on: October 10, 2006, 02:43:28 PM »
Last two pic's look just like my 78F.
If that helps.
The first two pic's bear more resemblance to a goldwing
Stranger in a strange land
Offline mcpuffett
« Reply #8 on: October 10, 2006, 02:58:00 PM »
the rear caliper on my 76' f1 has 2 pistons as standard , the pictures you showed were f1 caliper off bike and f2 caliper mounted on bike  ;),   mick.
Offline scondon
  • Mmmm......tasty bugs
« Reply #9 on: October 10, 2006, 06:07:59 PM »
Second that.
Offline 78 k550
« Reply #10 on: October 10, 2006, 08:50:25 PM »
If that helps.
Thank's All,
2 is better than  1 :) I wondering if I should swap them?
What kinda person do you think I would be if I had Goldwing parts lying around :)
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Clyde
« Reply #11 on: October 10, 2006, 10:39:32 PM »
I have used both of those calipers. My F1 which is stock has the first type - double acting and when I converted a K2 to rear disc with a F1 swingarm/wheel I used the second type which came of a early DOHC
If you want a perfect stock bike go with the double acting if you want the best caliper go with the single acting.
The double piston is much more prone to seizure and is also dearer to rebuild (two of everything and they are harder to get as the F/F1 caliper was only used on that bike from my knowledge).
The later type single piston works just as well (for a rear brake) and as it was used on a few Hondas (F2, Bol Dor CBX etc) is easier to get parts for. It is also lighter.
Just my thoughts
Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline KB02
« Reply #12 on: October 11, 2006, 06:10:40 AM »
Probably some bone head read in a magazine somewhere that you want to use the front brake for the majority of your stopping power (which you do) and so he desided to make the rear brake ornimental rather than functional on all bikes.
I'm sorry, but I HATE... actually, no... DESPISE soft. soggy, or weak rear brakes. And you can't get a modern bike with, what I consider, a decent rear brake. It's pathetic. I test rode a BMW K1200R. The bike has 163 horsepower. The thing is a monster!! You have to litterally stand on that rear brake peddel to get it stop the bike. My Ducati is not much better, either.
Okay, rant over (almost).
My F1 has the stock dual piston job. Stick with that. It's the better brake.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline 78 k550
« Reply #13 on: October 11, 2006, 08:55:09 AM »
Do they share the same pads?
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #14 on: October 11, 2006, 06:53:54 PM »
Paul,
I think the 76 rear dual piston caliper might be the same as your Wing uses?! I know it uses the same pads. EBC FA32 according to the new blister packed set I'm planning on using this winter.
