Author Topic: 9 screw clutch cover repairable?  (Read 908 times)
Offline Impala
« on: March 15, 2015, 10:14:36 AM »
Hello, I am looking for an artist of a welder/fabricator who can repair a missing screw tab on a cb750 9 screw clutch cover. Hoping it can be functional again and look good also as it is the top screw.  I have a donor 10 screw clutch cover that tab can be cut off from for repair or maybe enough new material can be added and a new tab reshaped/drilled/smoothed? Anybody have tried this? Saw a gentleman with a previous post here advertising  Micro welding for carb. castings. Any thoughts?  Thanks, Paul.
Offline strynboen
Re: 9 screw clutch cover repairable?
« Reply #1 on: March 15, 2015, 10:32:08 AM »
it can easy be veldet up...not use extern parts..tig can fill up..and be machined after..to be as new..go to a shop you trust..
i hate all this v-w.... vords
Offline kmb69
« Reply #2 on: March 15, 2015, 10:39:58 AM »
That would probably be Jim French, French's Micro Welding, Dacula, Georgia. His handle on this forum is "Jim F". Send him a PM and see what he thinks.
Keith
Offline eigenvector
« Reply #3 on: March 15, 2015, 10:52:20 AM »
 Yeah that can be fixed and fixed well.  Had a similar issue on my oil pan when the drain bolt housing cracked almost breaking it off (I hadn't quite figured out why oil drain bolts shouldn't be tightened down HARD when they leak slightly :-[)  Took it to a machinist - welded it up nicely and dare say it's better than the original casting.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #4 on: March 15, 2015, 11:10:42 AM »
 The aluminum color can be hard to match. Some guys have sliced rods out of a junk sprocket cover to help hide the repair.
Offline Impala
« Reply #5 on: March 15, 2015, 11:30:24 AM »
Any recommendations of someone. I am in Connecticut, USA.
Offline Vinhead1957
« Reply #6 on: March 16, 2015, 04:57:19 AM »
Might be less expensive to get one on eBay. Common part
Offline strynboen
« Reply #7 on: March 16, 2015, 09:18:59 AM »
is it a 1969-71 part?..they dont hang under threes for free..
Offline Impala
« Reply #8 on: March 16, 2015, 09:37:37 AM »
My understanding is the cover with the 9 screws holding it on were only on early 69 CB750 motors. Later covers have 10 screws. I would prefer to just replace cover, but they are  hard to find. If you know of one, I would gladly buy it. Thanks, Paul.
Offline Impala
Re: 9 screw clutch cover repairable?/Replacement out there?
« Reply #9 on: March 16, 2015, 09:40:54 AM »
Prefer to replace cover if anyone has one for sale. Thanks, Paul.
Offline Doum
« Reply #10 on: March 16, 2015, 09:47:56 AM »
clutch cover will be hard to find,I sold 2 of them in the last year on eBay and they go for 400$ each
Your cover is very simple to rebuilt.If you want to sell it,I will give you 100$ for :)
« Reply #11 on: March 16, 2015, 09:49:50 AM »
Sandcast only, No one has said the S word yet. I assume you know 9 bolts is rare and indicate a sandcast engine?  They are hard to find. A 10 bolt cover will fit but of course isn't correct for a restoration.
 Even if you find a replacement, it's worth fixing. A friend had an Inline 4 Indian engine repaired where a rod exited in the 60's. You can't tell by looking at the outside.  If the microwelding doesn't work out I can get his number, not cheap but worthwhile.
