Author Topic: 1977 CB750A forks and disc brake questions.  (Read 1531 times)
Offline dave77tac@gmail.com
« on: May 11, 2015, 05:43:33 PM »
Hello all, these question may seem like a no brainer, but I want to double check to make sure that I can do this switch. The Problem: I have a 1977 Cb750A and the forks are rusted, pitted badly, and need replaced, and I don't have the front disc brake calipers. I do have a complete 1980 CB750C  front forks, fender and disc brakes. The CB750C forks are about 2.5 inches longer than the CB750A forks. My questions are: 1. Can the longer forks be used?  (I can push them up through the triple tree the 2.5 inches to make the the same size and the stock forks on the CB750A).
2. Can I use the CB750C disc brake (I have all the brake parts; master cylinder, calipers, rotor. I would appreciate any feedback before I make the switch. Thanks
Offline jonnycakes
Re: 1977 CB750A forks and disc brake questions.
« Reply #1 on: May 16, 2015, 05:48:58 PM »
You can lower the forks internally.  I think spacing will be a problem with the rotor/caliper.  Anything can be done. I think A forks are a little longer than Ks.  K fork tubes are available everywhere fairly cheap.
'Matic-Fanatic
Offline nixon
« Reply #2 on: June 02, 2015, 05:05:12 AM »
if the forks are same diameter no problems sliding thru clamps if need be, again, cant see why you couldnt use brakes etc..
cb750a 77, cbr900rr 93 with auto clutch
Riding tip " turn in late, feeling great.  Turn in early,  feeling squirrely "
