Author Topic: How do you change the needle jets?  (Read 5171 times)
Offline eurban
Re: How do you change the needle jets?
« Reply #25 on: October 20, 2006, 04:36:32 AM »
Cutaway refers to the shape of the slide which has a section of its cylindrical shape "cut a way".  For many carb types changing the cutaway is an option and is a way of fine tuning the carbs (throttle settings between the idle circuit domination and needle clip position).  You can basically buy richer or leaner slides (cutaway changes) In theory this would also be the case with our stock 750 carbs but as far as I know there are no current suppliers of different slides.  Modifying with a grinder and welder might be an option but most people are unaware and ignore this area of carb tuning.  For our purposes, adjusting idle mix (perhaps swaping idle jets) adjusting needle clip position (as with slides needles with different tapers are available for some carbs but not ours) and main jet size are the easy options for carb tuning . . . . .
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #26 on: October 20, 2006, 05:10:01 AM »
When I do something for the first time, I like pictures. Here are a couple I took when I rebuilt a set:
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Jonesy
  • Shop Rat
« Reply #27 on: October 20, 2006, 08:13:00 AM »
So you say that buying a needle kit is the way to get the needle jets? What is the best route to go....please don't tell me the dealership cause I know thats going to be crazy expensive. Where has anyone picked these up for good quality & price ?
Sorry, but unless you can find a KeiHin parts dealers, Honda is the only way to go. the jet kits are $15 a pop....
tonys10
« Reply #28 on: November 12, 2006, 01:02:25 AM »
one more question...I too mine out but can't remember how they go back in...flat end or flared in up?
tonys10
« Reply #29 on: November 13, 2006, 12:50:20 AM »
bump
