Author Topic: [Video] Weird clacking noise from engine at idle  (Read 2436 times)
Offline NastyNip
  • oh snap
« on: May 30, 2015, 05:51:57 PM »
Hey there,
So my 1974 CB550 runs fine and dandy just after cold startup, and performs great for around the first 15min of riding, but after about 20min of fairly normal city riding, it starts acting up and the engine starts producing a noticeable mechanical "chugging" or "clacking" noise during idle. I have uploaded a video here, taken just after I got back from a ride:
Does anyone have any idea what this noise could be? After riding for 20 minutes, the bike sometimes feels like it wants to die at stoplights unless I give it some throttle, and I feel that I have to goose it extra when I come off the line. Any ideas?
The only thing non-stock is the MAC 4-1 exhaust which I have rejetted for. (one size up, now 40 105 jets)
I have recently adjusted the tappets and sync'd the carbs.
Thanks for any tips!
« Last Edit: May 31, 2015, 09:51:54 PM by NastyNip »
Cheers!
1974 CB550K
1978 CB550K
Offline toolguy
Re: [Video] Weird noise from engine at idle after riding a bit
« Reply #1 on: May 30, 2015, 07:35:14 PM »
should run a lot smoother at idle than that. .  Yours is missing at times, skipping a beat. .  may just need carb sync.  noise sounds like primary chain slap. .
« Reply #2 on: May 31, 2015, 06:19:16 AM »
Revisit the major maintenance items....set the valve lash, cam chain tension adjustment, timing/advance, and finish with a vacuum sync of your carbs.
Offline NastyNip
  • oh snap
« Reply #3 on: May 31, 2015, 12:51:00 PM »
 :-[ I just did those three last weekend, maybe take another pass at it? Adjusting valves is such a hassle...
« Last Edit: May 31, 2015, 02:48:28 PM by NastyNip »
Cheers!
1974 CB550K
1978 CB550K
Offline Tews19
  • I am no
« Reply #4 on: May 31, 2015, 01:48:09 PM »
sounds like chain slap. you stated you sync'd the carbs right?
1970 Honda CB750 survivor.
Offline NastyNip
  • oh snap
« Reply #5 on: May 31, 2015, 02:53:50 PM »
Yep I vacuum synced the carbs, adjusted idle mixture, adjusted valve clearances. Maybe I did a crappy job?
When you say chain slap, you referring to the cam chain right? I believe I adjusted it last week, but the adjustment knob didn't move too much.
Cheers!
1974 CB550K
1978 CB550K
Offline Tews19
  • I am no
« Reply #6 on: May 31, 2015, 03:04:32 PM »
You can adjust while running too. To me that sounds like primary chain if not cam. Or did you pull in clutch while running to see if it quiets?
Offline NastyNip
  • oh snap
« Reply #7 on: May 31, 2015, 09:51:31 PM »
Ah, I didn't know you could adjust the cam chain while running, good to know.
I found this thread from a few months ago, and the guy posted a video very similar to mine:
http://forums.sohc4.net/index.php/topic,139999.msg1585399.htm
Seemed to point to a carb sync issue, so maybe I just need to take another pass at it.
Cheers!
1974 CB550K
1978 CB550K
Offline heyitsrama
Re: [Video] Weird clacking noise from engine at idle
« Reply #8 on: May 31, 2015, 11:12:39 PM »
How is compression across the cylinders?
My old motor sounded like that when it had around 70PSI in cylinder 4. I posted a video of mine a while back its somewhere in my profile.
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline NastyNip
  • oh snap
« Reply #9 on: June 01, 2015, 01:17:37 PM »
Compression is good, I checked last weekend.
So I pulled the clutch in, and indeed the sound goes away. Does that mean it's the primary chain? ...Do I have to split the case? :(
Cheers!
1974 CB550K
1978 CB550K
Offline Tews19
  • I am no
« Reply #10 on: June 01, 2015, 02:34:11 PM »
Nope. Sound is normal. You can swap out the clutch plates if you want. Do a search for clutch basket noise. Nothing to worry about though.
Offline NastyNip
  • oh snap
« Reply #11 on: June 01, 2015, 09:54:41 PM »
So you're saying it's the clutch (worn out) and not the primary chain? Is there any way to verify this before I pull the basket?
Regardless, I'd be way happier to replace the clutch than the primary chain. :)
Cheers!
1974 CB550K
1978 CB550K
Wobbly
« Reply #12 on: June 02, 2015, 01:11:03 AM »
If the noise goes away after pulling the clutch, then it's the clutch basket. It's very common for the SOHC 4 Honda bikes.
« Reply #13 on: June 02, 2015, 01:26:03 AM »
+1, also, when the carb sync is out, these engines sound like they are full of nuts and bolts, they rattle their heads off... ;)
Offline NastyNip
  • oh snap
« Reply #14 on: June 02, 2015, 02:07:41 PM »
Thanks for the great advice guys.  ;D
I'm picking up plates, springs and a gasket today and will put it on my to-do list for this weekend (along with another pass at a carb sync)
I'll report back with results!
Cheers!
1974 CB550K
1978 CB550K
