Author Topic: What is damaged from reversed battery terminals?  (Read 1590 times)
Offline jayowen
« on: June 01, 2015, 11:36:04 PM »
So my bike died today while trying to start away from home. Fiancé came and got the battery and charged it for me. After being charged I stupidly put the battery in wrong causing the terminals to be reversed. What did I break and need to replace? :-( not the best day
Re: What is damaged from reversed battery terminals?
« Reply #1 on: June 02, 2015, 03:44:39 AM »
Maybe nothing.  There are bikes - and other vehicles - with (+) on the frame.  Ural for instance.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: June 02, 2015, 08:23:43 AM »
Fuse.
Offline jayowen
« Reply #3 on: June 02, 2015, 09:33:49 AM »
Yay just a fuse
« Reply #4 on: June 02, 2015, 10:19:59 AM »
Any smoke? Check the wiring to your rectifier, etc.
Offline PGF550F
« Reply #5 on: June 02, 2015, 11:19:10 AM »
Ground wire on the Rectifier takes the biggest hit... and the Ego ;)
« Reply #6 on: June 02, 2015, 12:51:39 PM »
 Advance auto had their battery chart incorrect. The sales guy kept trying to sell me batteries with the poles reversed. He even called the manufacturer. This year I went to the battery rack and found it myself.
 I've been told it can ruin the rectifier.
Offline Bodi
« Reply #7 on: June 02, 2015, 02:03:53 PM »
"Could" ruin the rectifier should be "Will" ruin the rectifier - it's connected to the battery directly with no fuse. The starter safety module could also be fried if you have one but the key would need to be on.
Offline mcswny
« Reply #8 on: June 02, 2015, 02:07:07 PM »
Any update Jay?
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline jayowen
« Reply #9 on: June 02, 2015, 04:30:28 PM »
changed out the plugs and it ran and rode around fine. its at my work until tomorrow until i can get someone to take me to it to bring it home to test charging and what not. but soooooo far it looks like fuses
Offline mcswny
« Reply #10 on: June 02, 2015, 05:19:24 PM »
fingers crossed for the best!
1972 CB750 K2
1975 XL250
198 XR80
Offline xtravbx
« Reply #11 on: June 03, 2015, 05:03:53 AM »
I've done this. And you probably cooked wiring going to the rectifier. Doubtful you even popped a fuse, I didn't. Look for melted wire sheath and replace as necessary. Definitely an ego hit. In my defense the terminals were flipped on my gel battery.
Offline jayowen
« Reply #12 on: June 04, 2015, 09:07:11 PM »
my terminals were reversed too. :-( but replaced main fuse and good to go. no damage to rectifier or wiring
Offline mcswny
« Reply #13 on: June 05, 2015, 06:57:41 AM »
good to hear!!!
1972 CB750 K2
1975 XL250
198 XR80
