Author Topic: Am I an idiot or just plain stupid?? 1965 Triumph in house, work begun  (Read 19391 times)
Offline MoMo
  • Ride like you're invisible
Beautiful work Larry, and good idea to keep it on the road while you're restoring it, once you strip it down it's no longer a bike, it's just a pile of parts. ;D
Thanks again, Terry and ................................................I already have two or three bikes that are "piles of parts".  G'day...Larry
Offline MoMo
Restored the air filter today and pulled Red Rider out of long term storage
Carb and air filter before:
Redid the rusty housing and polished the chrome band:
Going to post some photos of Red Rider ....Larry
What's a "red rider" Larry? Not another golf cart, I hope? ;D
Offline MoMo
Guess you saw the new post of the rotted frame??
Yeah, sorry mate, my memory isn't what it used to be.......... ;D
I picked up a nice cb550 front wheel from a fellow up in Phoenix when I lived in Sierra Vista, He had a cool Triumph in frame he was rebuilding and had gone through the motor.  He had a great 50s truck done up with classic weathered looks and the dry desert climate wouldn't change the level of patina from rust but would weather and fade any remaining paint. It was a cool truck with classic 60s air cooler that had a tube filled with water and fan that serves as a swamp cooler style air conditioning for the truck. The bed was redone with wooden slats bed floor that had the UV stable Spar Urethane finish, beautiful stuff.  It was street rodded. I think his intent wss to build it as a chopper style or similar.  He was a cool guy.
it was interesting to see the Honda stuff from a fellow into British bikes.
Nothing from preventing you from outfitting it with dual drilled disc of something with decent calipers and rotors.
Offline MoMo
No there isn't except time and money , got the battery today, plan to finish the DS6 then make the Tri roadworthy as is, then make it as stock as possible without spending a boatload of bucks...Larry
That's it Larry, ride that beautiful old Trumpy and just upgrade it as you go. That's what I'm doing with most of my bikes, I don't have time for trailer queens. Cheers, Terry. ;D
Offline BPellerine
you can get the amals sleeved with better slides ,makes a big diff and they don't wear so fast.the metal they were made from was really bad.bill
1978 CB 750K ard and webers
another anfob
Offline MoMo
thanks for the tip BP.  Bike only has one Amal so it may not be much of  problem.  I am fairly sure this was a Bonneville at one time and someone installed the single carb....Larry
The SU HS6 carbs on my 66 122S had worn shafts for the throttle butterfly causing air leaks and a fellow in Mass had a business replacement shafts and boring the bodies with a rebushing them with it delrin reamed to size of the shafts. It was worth the investment and twin SUs were so much more fun, even with seasonal tuning the SUs required.
So, get the carb solid and it will make it run well and take a unknown curve out of the troubleshooting.
Leaky carbs can really make it hard to tune and run optimal.
Nothing you don't know.
A dual piston caliper could solve the braking challenges at the expense of period looks, or a pair of single piston calipers like off a honda might work.
Take a page from FunJimmy's approach with a twist....
he used a modern std fork with multiple pot caliper and single drilled disc. His approach was high $ but, twist the equation.
Source a decent pair of fork tubes that can provide damping you want, hopefully the trees are compatible.  Otherwise it starts getting pricey too fast.
All balls replacement bearings for the different forks and trees. Then the axle and wheels that can look close enough.
Maybe your current forks are fine and just need replacement tubes to remove the chopper rake.
Then adapter for a good caliper picked up cheaply and rebuild it.
« Last Edit: July 12, 2015, 09:26:01 PM by RAF122S »
 Looks like fun to me, enjoy it.
Offline MoMo
thanks Don,  one thing it will be as is is a good vibrating exercise machine...Larry
I missed the updates, nice clean-up of red rider filter body.  You did nice work on that Amal carb too. That should be easier to feel the difference now and better across the entire range.
 Scorpion batteries worth the investment?
As always Larry,  you do fine work and it looks great!
I have a couple Honda calipers you might like to consider for your Triumph if you want to adapt them.
Call me sometime and I will tell you about them and you can see if they might be interesting.
« Last Edit: July 13, 2015, 08:15:20 AM by RAF122S »
Re: Getting that Amal resleeved, another option is putting a Mikuni on it Larry. Lots of Trumpy, BSA and Norton owners install them because they're so simple, and well engineered. Keep the Amal in a box for when you sell the bike.......... ;D
Offline simon#42
  • liverpool
i would fit a mikuni , they always seem to work well and will outlast a box full of amal's
Offline MoMo
any particular size or is there a "standard procedure" that people do....Larry
Check triumph mikuni kit on ebay...problem will get you something..
ken65
with my tired worn out amals, nothing worked, popped a pair of new premier amals on , balanced and bingo.
starts 1st kick every time nobodies watching and settles into a nice 900 rpm idle after a minute.
they look the part and you still have the choke lever on the bars. But the mikuni has a solid reputation.  ken
+1 for mikuni's... ;)
Offline MoMo
thanks for the responses. I'll check out Feebay...Larry
Larry, what is the ID of the manifold where the carb meets the head?
Offline MoMo
I'll check it out and get back, thanks
Not sure if this will work...
This site has some good information about fitting Mikunis to Brit twins:
http://www.mikunioz.com/product-category/vm-carburetors/vm34-carb/
