Author Topic: 77-78 CB750F Block seal question  (Read 576 times)
Offline TurboD
« on: June 07, 2015, 08:12:18 PM »
I have a cylinder assembly from a 77-78 CB750F which used the "sleeve" O ring seals at the top of the block.
My Question is. Are these seals needed when this block is used with a K head? I don't see a need for them.
Re: 77-78 CB750F Block seal question
« Reply #1 on: June 07, 2015, 08:18:29 PM »
I omitted them in my build.
Offline koendd
« Reply #2 on: June 08, 2015, 01:12:30 PM »
I just finished my F2 build and I did use them.
i had a K head on my F2 before and they were on there as well.
I did modify them a bit because they were sitting just a little bit higher then the cylinders.
Also, I'd suggest using K pistons too, otherwise you'll have a lot of compression and the chance of valves touching pistons (don't ask me how I know)
you need to modify underside of the cylinders too (oil return)
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
