Author Topic: What type and size tool is used to remove brake caliper on CB750K4?  (Read 5171 times)
Offline Ausmithe
So I just last night brought home a 74 CB750, with 620 original miles on it. It runs and idles well, and had been very well taken care of so I'm pretty excited . I've had a CB500 that I've been working on riding for the last few years that I sold to be able to purchase the 750. My impression while having the 500  was that it was a very similar bike to the 750 but I'm seeing that there are much more differences than I'd thought. That being said I'm familiar the work I need to do to clean my brake caliper, because it's sticking, however I don't know the size of the needed tool to remove the two bolts holding on the caliper. It looks to be a large Alan wrench.
Any help is appreciated.
1974 CB750
1972 CB500
Offline Garage_guy_chris
Re: What type and size tool is used to remove brake caliper on CB750K4?
« Reply #1 on: July 09, 2015, 03:03:56 PM »
yes large metric allen wrench will work, i suggest getting a set of allen socket things for working on the bikes.
Offline Ausmithe
« Reply #2 on: July 09, 2015, 03:07:15 PM »
Great, but does anyone know the specific size needed for this particular job?
1974 CB750
1972 CB500
« Reply #3 on: July 09, 2015, 03:18:43 PM »
Yes, it's 8mm.   You prolly just need to clen the inside of the caliper and install a new seal, pretty basic.
Tip: before you disconnect your brake line, loosen the caliper and pump the piston out.  Much easier this way.
Offline Ausmithe
« Reply #4 on: July 09, 2015, 03:21:18 PM »
Thanks Stev-o, I wanted to be sure that I had the correct size if I buy a set.
Thanks as well for the tip on popping out the piston!
1974 CB750
1972 CB500
« Reply #5 on: July 09, 2015, 03:35:53 PM »
Happy to help.   That is a sweet looking bike, I think you did real well and would think it is a big improvement over a 500.
Offline Ausmithe
« Reply #6 on: July 09, 2015, 03:37:09 PM »
Huge improvement. I loved my 500 but I really had no idea of what I was missing.
1974 CB750
1972 CB500
« Reply #7 on: July 09, 2015, 03:41:05 PM »
8 mm or5/16.  Pretty much the same..and if that is not correct its 10mm.
 Nice bike BTW...
« Last Edit: July 09, 2015, 03:45:02 PM by 754 »
Offline Ausmithe
« Reply #8 on: July 09, 2015, 03:50:11 PM »
So clearly I need to purchase new tires since it still has the originals on it. I had someone at a bike shop suggest the Conti Twins . Anyone have recommendations?
1974 CB750
1972 CB500
« Reply #9 on: July 09, 2015, 04:01:46 PM »
ContiTwins are very good, but pricey. I have Bridgestone BT45's on my K4 and like them a lot.  Avon RoadRiders are also very good.
https://www.denniskirk.com/542151.sku?utm_source=pricegrabber&utm_medium=cse
BTW - where are you?
Offline Ausmithe
« Reply #10 on: July 09, 2015, 04:04:42 PM »
Louisville KY.
I thought the Contis were pretty pricey too.
1974 CB750
1972 CB500
Offline Powderman
« Reply #11 on: July 09, 2015, 04:12:56 PM »
Is that 620 original mileage? Are the tires original to the bike with 620 miles on them. Tread should be more than adequate but they are probably dry out to the max if they are 45 years old.
« Reply #12 on: July 09, 2015, 04:17:31 PM »
Highly doubt it, PM!
Offline MoMo
  • Ride like you're invisible
« Reply #13 on: July 09, 2015, 04:21:42 PM »
Said it in his opening sentence!!
Offline Ausmithe
« Reply #14 on: July 09, 2015, 04:23:05 PM »
It's original mileage , and the tires are the original tires. The bolts on the bike still have the factory yellow paint on them and plastic on the back of the mirrors.
1974 CB750
1972 CB500
Offline Powderman
« Reply #15 on: July 09, 2015, 06:14:51 PM »
I'm a billionaire.
Offline Powderman
« Reply #16 on: July 09, 2015, 06:15:15 PM »
You going to actually start racking up miles on this?
Offline MoMo
« Reply #18 on: July 09, 2015, 09:19:58 PM »
I'm a billionaire.
Me too!
Yeah,  well..............................I own a bridge in Brooklyn.
Offline Powderman
« Reply #19 on: July 09, 2015, 10:08:50 PM »
I'm a billionaire.
Me too!
I thought I remembered you. You're the one that bought that from me
« Reply #20 on: July 09, 2015, 10:16:05 PM »
Museum bike. I felt bad taking my 76SS from 9K to 12K miles and I'm committed to keeping the sandcast under 10K. Have a blast showing her off!
Offline Johnie
« Reply #21 on: July 10, 2015, 03:18:40 PM »
Excellent bike there. I have Continental tires on all my 750's. I was looking for a vintage tire pattern and this is what the board suggested like 7 years ago. Now Dunlop also makes the vintage Gold Seal tire I hear. Was going to check those out at some point. Have had real good luck with my Conti's.
« Last Edit: July 10, 2015, 03:20:50 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Ausmithe
« Reply #22 on: July 10, 2015, 05:32:02 PM »
While I can understand the skepticism about the original mileage on this bike, I can assure that this bike has only 620 miles on it. The question was asked about whether or not I was going to rack up miles on it, and the answer is yes. But that being said, it will not be much, as I rarely ride more than the 6 miles to and from work. But my view on it is that I am sure there are several CB750s sitting in vintage bike museums, or collectors garages that won't uptick another mile. My bike however is going to be enjoyed.
The backstory on this bike is that it was purchased along with another just like for a father and son when new. The son rode his bike over the course of the next 30 years, but the father only put about 400 miles on it before passing. His son kept the bike stored until about 2005 and decided to sell to his brother-in-law. The brother-in-law kept the bike for 10 years and only put about 200 miles on it because he, like many people would choose, didn't want to rack up many miles on this bike. He had a Harley that he regularly rode so he just kept this bike under a motorcycle cover in his garage for the last 10 years, starting it up once or twice to let it run each year but not riding it. After 10 years, this year, he decided to sell because he wasn't riding it and felt like it was a waste to just sit in his garage. So he agreed to let me buy it.
It is not pristine. There are small rust spots on the chrome of the wheels, and there is corrosion on some parts of the engine covers as well as one of the front forks. This is easily taken care of however, and the bike is something that I am going to thoroughly enjoy...by riding it. I doubt i'll put more than 1200 miles /year on it but maybe this bike will spur me to riding more. I can say that after my first ride, it was a major blast compared to the 500 i've been riding for the last few years.
1974 CB750
1972 CB500
Offline Ausmithe
« Reply #23 on: July 10, 2015, 05:52:41 PM »
Here's a pic of the protective plastic on the back of the mirrors.
1974 CB750
1972 CB500
« Reply #24 on: July 10, 2015, 07:14:46 PM »
Great story and find, congrats to you.   Ride 'em!
