Author Topic: CB550 - removed/reinstalled rear wheel, now brake is gone?  (Read 1721 times)
Offline xtravbx
« on: July 10, 2015, 06:32:24 PM »
Took off my wheels, had new tires installed.
Re-Installed everything, hooked up the rear brake linkage, never touched the adjusting rod at all, now when I press on the rear pedal, there is zero stop. It bottoms out without even CLOSE to applying the rear brake.
Is there something inside the rear brake hub that I should have looked at before reassembly?
I'm going to take the wheel off again tomorrow and look it over.
Also, I snapped the spring that connects the rear brake light switch because it bottomed out too hard. Frustrating. Anyone know where to get a quick replacement for that?
Offline rb550four
Re: CB550 - removed/reinstalled rear wheel, now brake is gone?
« Reply #1 on: July 10, 2015, 06:37:33 PM »
Did you put in new shoes since you got it? If not perhaps the pad on the shoes have fallen off.
Offline xtravbx
« Reply #2 on: July 10, 2015, 07:01:24 PM »
Didn't touch the pads, I'll look inside and make sure they didn't fall off.
Note:
Prior to the new tires, the brake was completely fine. I was riding it regularly.
Thanks RB
Offline jonda500
« Reply #3 on: July 10, 2015, 07:11:53 PM »
so if you didn't touch the adjuster, you must have instead removed the brake actuation arm - when reinstalling it onto the splines there's two little pimples that tell you where to locate it - yours must be angled too far forward?
John
A starter clutch thread:
Offline xtravbx
« Reply #4 on: July 10, 2015, 09:05:31 PM »
Yeah I took the arm off the splines and left the adjuster completely in place and "non-adjusted" if you will.
I will look for the dimples and take apart re-assemble tomorrow.
Always a struggle with these old machines.
Sent from my SCH-I545 using Tapatalk
Offline SohRon
« Reply #5 on: July 11, 2015, 08:14:05 AM »
A couple of shots that show orientation of the levers:
Notice how the brake rod connector is positioned at the pedal shaft with the curve to the bottom.
This thread may be of some help:
http://forums.sohc4.net/index.php/topic,86697.msg1420417.html#msg1420417
« Last Edit: July 11, 2015, 08:42:44 AM by SohRon »
Offline xtravbx
« Reply #6 on: July 11, 2015, 12:08:40 PM »
Thanks guys!! Awesome.
Offline xtravbx
« Reply #7 on: July 13, 2015, 09:49:54 AM »
FYI got this fixed. Simply needed the attached arm at a different angle so it would engage fully when pressing the rear brake lever. All the help was appreciated and aided in my fix.
Offline sammermpc
« Reply #8 on: July 13, 2015, 11:00:25 AM »
Funny how the world works — I just had this problem yesterday after re-installing my rear brake! It was indeed a question of lining up the dimples on the pedals. Thanks again for your superlative photos, Ron.
1972 CB500, 1979 CB750F SS (dohc), 1982 Yamaha Maxim XS400
Offline Deltarider
« Reply #9 on: July 13, 2015, 11:12:33 AM »
Great info, Sohron. You knpw, I own my bike since 1980 and never knew it had these little dots. Not that I needed them (so far I never had to detach these levers) but it is good to know.
CB500K2-ED Excel black
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #10 on: July 14, 2015, 01:18:51 AM »
Sohron: A favor please? Would you mind posting "GET YOUR SUNGLASSES ON NOW - PIX TO FOLLOW" prior to every time you put up one of the (gorgeous) detail shots of your (perfect) bike(s).  Damn things are so impossibly shiny and well lit my retinas scream for mercy.
Thank you.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
