Author Topic: Gap between bearing retainer and hub... normal? CB500  (Read 556 times)
Offline Puffin
« on: July 25, 2015, 05:01:53 PM »
Hi all,
I was having trouble with setting the chain alignment and noticed the sprocket would move as I brought the chain up to the correct tension.
Anyways I worked backwards and ended up taking the wheel back out and checking everything was installed correctly.
What I found is that the bearing retainer is clamping down on the bearing but there is a 1-2mm gap between the bearing retainer and the sprocket hub.  This allows the hub to 'float' which in turn causes the spocket to tilt slightly when under tension.
Have I explained that clearly?   Some photos below to clarify..
Is this normal or should the bearing retainer sit flush with the hub?
I have new All-Balls bearings in and as far as I can tell they are properly seated.  I can put my finger in and move the internal spacer around but I can't physically drive the hub-side bearing in any more.  The brake side bearing sits flush with the hub.
I can't tighten the retainer down any more as it's seating on the bearing.  Have I done something wrong or is this normal?
« Last Edit: July 26, 2015, 09:38:29 PM by Puffin »
Honda CB500 four
Honda CB350 four (under construction)
1972 Cb500 Rebuild Project - http://forums.sohc4.net/index.php/topic,145835.0.html
Offline Puffin
Re: Gap between bearing retainer and hub... normal? CB500
« Reply #1 on: July 26, 2015, 09:38:51 PM »
Anybody?
Honda CB500 four
Offline Puffin
« Reply #2 on: July 27, 2015, 02:49:30 PM »
Thanks Cal....
Honda CB500 four
