Author Topic: Help with rear sprocket / bolt patterns / teeth  (Read 1416 times)
Offline riffman12
« on: August 28, 2015, 12:17:37 PM »
Apologies if this is a bit confusing. I'll try to be concise:
So my bike is a '76 750F with a '77 750F front end, rear swingarm, and wheels (for dual disks). Wheels I got with the bike were bent so I bought a pair of comstars from a '79 CBX. Everything lines up correctly, only issue is the rear sprocket:
The bent wheels that came with the bike use the older bolt pattern for the rear sprocket
The new CBX use the 5 bolt rear sprocket, but it's only a 35 tooth rear sprocket (much smaller than stock).
Where can I get a rear sprocket with the CBX 5 bolt pattern that has the same correct amount of teeth for a '76 F? (48T i think?)
Did they continue the CBX bolt pattern for future sport bikes?
Thanks for the help
Offline jeffg
Re: Help with rear sprocket / bolt patterns / teeth
« Reply #1 on: August 28, 2015, 12:51:24 PM »
you might only be able to get a 38 tooth rear for the cbx. You would want to drop the front to a 13 tooth, then you should achieve close to stock ratio.  I guess that's ok.
 http://www.jtsprockets.com/catalogue/model/5058
these guys maybe can help you
http://shop.pbisprockets.com/product.sc?productId=167&categoryId=18
« Last Edit: August 28, 2015, 01:10:55 PM by jeffg »
Offline Duanob
  • Bold Timer
  • Gotcha!
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline mrfish2
  • I might be a
« Reply #3 on: August 28, 2015, 03:52:42 PM »
If you don't think the links posted above will help you then simply email JT. They are usually good with getting back to people and are very helpful in their customer service.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline riffman12
« Reply #4 on: August 31, 2015, 12:10:48 PM »
thanks a lot guys. I will take a look at those links
