Author Topic: 74 750 kickstand length?  (Read 1077 times)
Offline Garage_guy_chris
« on: September 21, 2015, 08:04:41 PM »
Alright so the kickstand on the bike is wrong someone cut it down and i have to carry a piece of wood to even it out and its getting annoying and or the bike is gonna fall over.  I have a few mystery kickstands so i was hoping someone could measure their so I can pick one to switch the stubby out with.
please measure bolt center to heel if possible.
thank you once again for helping me correct my frankenbike!
Re: 74 750 kickstand length?
« Reply #1 on: September 21, 2015, 08:20:29 PM »
be sure your frame tabs and the tabs on the stand itself are not bent as this will also make the bike lean over too far.  Also even a whopped out pivot bolt and/or hole will affect this negatively.  I used a stand from a '76 550f once when I needed a longer than stock stand for my 750...kinda odd that the 550 stand was longer.
« Reply #2 on: September 21, 2015, 08:31:08 PM »
Everything is relatively ok with the frame tab and bolt. You can see someone has cut off the original foot and obviously part of the shaft and welded a new foot on. It looked ok but with no wheels or engine it was kinda hard to check the funtionality of it. Now that its finished its no bueno.
« Reply #3 on: September 21, 2015, 08:49:51 PM »
7.25"
