Author Topic: Frame tube modification - pictures needed!  (Read 1757 times)
Offline livefast_dieold
« on: October 23, 2015, 06:45:56 AM »
Hi everyone,
I've searched the forum a lot, but I could not find any picture of a very nice frame modification I've saw a couple of year ago here.
The two straight tubes from the steering head, on top of the engine, were partially removed, and substituted with two curved tubes so it was possible to remove the head with the engine still in place.
I'm seriously thinking to do such modification... any suggestion? Do you think frame stiffness will be affected too much?
Thanks in advance for any help provided!
Offline kmb69
Re: Frame tube modification - pictures needed!
« Reply #1 on: October 23, 2015, 06:50:51 AM »
Sounds like your are describing an automatic frame. They have the curved top rails.
« Reply #2 on: October 23, 2015, 08:19:22 AM »
If you do that you probably need to clearance the gas tank, or use the A Tank.
I can. Tell you a weldless kit , is a quick easy way to be able to remove the topend. Only about 2 hrs to install.
« Reply #3 on: October 23, 2015, 05:08:18 PM »
Mhhh I rather not pick that option, I don't want to add weight!
No one has a pic of an hondamatic frame?
« Reply #4 on: October 23, 2015, 05:38:07 PM »
Weldless weighs about 450 grams... Weld in kits around 3.5 lbs..
The Auto frame has some extra brackets and mounts, its probably heavier than the K and F frames.
« Last Edit: October 23, 2015, 06:57:23 PM by 754 »
Offline BPellerine
« Reply #5 on: October 23, 2015, 05:41:38 PM »
do a search,period pro stock sohc,member Greg H ,he did the mod you are talking about.billp
1978 CB 750K ard and webers
another anfob
« Reply #6 on: October 23, 2015, 05:49:39 PM »
 I used the old original weld in kit, they are heavy. I did counter bore the slugs part way through just to lighten them a little.
Offline Old Scrambler
« Reply #7 on: October 24, 2015, 01:27:35 PM »
Several Auto-frame pics in my thread: http://forums.sohc4.net/index.php/topic,135473.0.html
The original frame before mods is about half-way down on the first page......several more later..........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Greg H
  • When two cams is one too many .
  • Still crazy after all these years .
« Reply #8 on: October 24, 2015, 02:10:21 PM »
Hi , I tried to knock up a pair of bent tubes , but no matter how I did it I experienced clearance problems with the dummy glass fibre fuel tank I used . So I went with straight tubes .
« Reply #9 on: October 25, 2015, 04:43:05 AM »
Nice modification!!!
I'm still thiking whether to do it or not...
Offline Greg H
« Reply #10 on: October 25, 2015, 09:08:23 AM »
Thanks  ;). I thought about doing away with the side rails altogether, but decided against it,as I'm a little too long in the tooth for those sort of shenanigans now ;D ;D.
