Author Topic: 1974 CB750 Bobber  (Read 2445 times)
Offline xburgerx
    • Stray Dogs
1974 CB750 Bobber
« on: January 22, 2016, 10:15:44 AM »
Still a rookie both on here and in the bike community in general. Here's my '74 build thus far... Getting the custom exhaust fitted this weekend. Doing this in a cluttered garage with limited lighting in subzero temps is enough to make a dude grind his teeth to powder.
Cleveland Straightedge
Offline h0tr0d18
Re: 1974 CB750 Bobber
« Reply #1 on: January 22, 2016, 02:09:23 PM »
Following!! I am going to check out a few different CB 750 engines tomorrow to start my build. I have a left over neck and tubing from a previous build that I'll be using to build my frame from scratch. I like what you have done so far, I'll also be doing a Bobber of sorts.
Offline irish44395
« Reply #2 on: January 22, 2016, 03:51:25 PM »
I'm Liking it. I only wish I had  a garage to work in I have a shed but I live in Florida so I am not freezing
Pete
« Reply #3 on: January 22, 2016, 07:49:02 PM »
Hey I am trying to he nice here,
...search FLH chrome under seat cover..
 You need your own version of this but in black..it would really help it look good
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #4 on: January 23, 2016, 05:52:45 AM »
looking good.  keep an eye on those straps under the seat.  you will have a lot of stress where those weld to the frame.
Offline xburgerx
    • Stray Dogs
« Reply #5 on: January 25, 2016, 06:29:59 AM »
Don't worry about being "nice"... I need input. I can handle criticism without the sugar.
I don't know what you mean about the covers though. I haven't mounted the rear fender yet or quite a few other things. I looked those up and still am scratching my head and slobbering on myself.
« Reply #6 on: January 25, 2016, 10:20:20 AM »
I keant cover up the area of the frame with the flat straps so it looks cleaner.
Offline Desert-SOHC
  • It's old
« Reply #7 on: January 25, 2016, 04:45:38 PM »
If it were mine I would tie in the tubes to strengthen that area and build a cover plate for it like 754 was talkin about.
I like where its goin though.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline xburgerx
    • Stray Dogs
« Reply #8 on: January 26, 2016, 04:46:31 AM »
Ok. I get what you're saying. I'll have to check for allowance because my oil tank is also a battery box combo and the battery is going to rest beneath the seat. Should be fine though because I laid the seat flat with no springs and there was still a pretty decent gap before the battery.
Offline xburgerx
    • Stray Dogs
« Reply #9 on: January 26, 2016, 04:47:44 AM »
Thanks, man. I'll see what I can muster up.
Offline knowsnothing
« Reply #10 on: January 26, 2016, 07:15:57 AM »
Nice work so far!  Could you post a pic with the tank off.  It looks like you have done a little cutting and pasting, just curious.
1978 CB750k Blue - for sale
Offline xburgerx
    • Stray Dogs
« Reply #11 on: January 26, 2016, 09:52:30 AM »
When the bike is back in my custody I absolutely will. It's getting a custom exhaust built at Strange Cycle here in Cleveland right now. We did cut the bottom two bars right behind the coil housing. Then we heated them and bent them in and up to the center spine. They're still functional by means of support, but also out of the way for the petcock on this sportster tank. Good eye.
