Author Topic: Lester Wheels questions  (Read 8293 times)
Offline Rookster
Re: Lester Wheels questions
« Reply #25 on: January 27, 2016, 01:17:01 PM »
The outer rim was polished after machining.  The hi-lighted spokes were machined.  As has already been stated the paint was a semi-gloss black.  The Lesters do not have flats on the front to locate the speedo drive so you will either have to pin the speedo drive to the hub or cut reliefs into the back of the 2nd disk.
Here is a write-up I did for the dual disk Lester wheel. http://forums.sohc4.net/index.php/topic,91781.msg1025007.html#msg1025007
Scott
Offline Eydugstr
« Reply #26 on: January 29, 2016, 01:49:00 PM »
Looks good, Jerry!
