Author Topic: Valve Guide Clip - 12211-250-310  (Read 1778 times)
Offline motobonita
    • Motobonita
« on: February 22, 2016, 04:23:54 PM »
Is the valve guide clip (PN 12211-250-310) in the drawing for the 1976 CB750 F the one that's on the valve guide seal? Or is this another valve guide clip that goes on the guide somewhere?
www.motobonita.com
Thank you,
Chris
Offline kmb69
Re: Valve Guide Clip - 12211-250-310
« Reply #1 on: February 22, 2016, 07:25:04 PM »
That clip goes on the valve guides to locate their height in the head. They are essentially a stop.
Offline motobonita
    • Motobonita
« Reply #2 on: February 23, 2016, 06:35:33 AM »
so place the clip on the guide right where it meets the top of the head?  The guide has a grove on it that should stop it.
Offline motobonita
    • Motobonita
« Reply #3 on: February 23, 2016, 06:39:57 AM »
Also, the drawing doesn't have the valve guide seal on it.
http://www.hondachopper.com/engine/fiche_pages/F0/F0-Head.pdf
The valve guide seals have a similar clip on them.
http://www.cb750supply.com/images/cb750supply/parts/480/CB-70402.jpg
Thank you all.
« Reply #4 on: February 23, 2016, 07:45:36 AM »
Yes.
Offline motobonita
    • Motobonita
« Reply #5 on: February 23, 2016, 06:11:55 PM »
This was answered extremely well on the other forum.  Case closed.  No need to buy the clips if you have aftermarket valve guides.  Do buy the clips if you have (for some reason) OEM guides.
http://www.cb750.com/threads/3502-Valve-Guide-Clip-12211-250-310?highlight=motobonita
