Author Topic: Adhesive for metal badges  (Read 1034 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: February 28, 2016, 12:09:35 pm »
So I just painted my K1 tank and had to take the metal badges off. I want to get them back on with an adhesive that:
1. Will hold
2. Not wreck the hard body and paint work I just put into this bike.
Any suggestions?
Sent from my SM-N900V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline 540nova
Re: Adhesive for metal badges
« Reply #1 on: February 28, 2016, 01:58:42 pm »
3M trim adhesive
Online Stev-o
« Reply #2 on: February 28, 2016, 02:51:47 pm »
"Amazing Goop", get it at HD for $5.
I just used some on freshly painted side covers.
http://www.homedepot.com/p/Amazing-Goop-3-7-fl-oz-All-Purpose-Adhesive-140211/202533796
Offline Vinhead1957
« Reply #3 on: February 28, 2016, 03:32:37 pm »
+1 on 3M trim tape
Offline George_s
« Reply #4 on: February 28, 2016, 06:40:05 pm »
I've had good luck with plain old adhesive caulk.
« Reply #5 on: February 29, 2016, 01:49:21 am »
The tank has no OEM fastener, clips that hold the tank badges? No need of anything more
http://motorcyclesolutionsllc.com/emblem-clips-4ea-cb350-cb400-cb550-cb750-87311-634-600-87311-634-600
DH
« Reply #6 on: February 29, 2016, 06:49:37 am »
+2 on 3m two sided tape. I think it comes in different thicknesses. Once applied, it's hard to remove, and it'll last
a LONG time. It's for automotive use. One of the sidecover badges on my 550 has it due to broken pegs, and its
held for several years now. I'd apply it after giving your paint time to completely cure, but you knew that...
Offline Kenzo
« Reply #7 on: February 29, 2016, 10:02:53 am »
Probably not needed but I would let the paint degas and cure a bit before I did anything like that but I'm goofy that way....3M tape gets my vote! :)
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
« Reply #8 on: February 29, 2016, 12:51:07 pm »
I ad mixed results with 3m tape when using on a  chrome plastic grill for some high mileage club badges .  But, on cured paint you'll be cursing it if you have to redo the paint work down the road as it sticks like gorilla snot.
Speaking of gorilla
Gorilla glue would work but it is extremely tough and difficlt to remove if it didnt foam up from enough water, controlling excess foam can be a pain too.
White version doesn't foam as much but shelf life is short on either.
So, Im with camp of 3m tape and then goop.
« Last Edit: February 29, 2016, 12:54:02 pm by RAF122S »
