Author Topic: Calipers & Forks  (Read 1241 times)
CB925
Calipers & Forks
« on: November 11, 2006, 07:09:50 PM »
Hi, I realise part of this question has been covered in various places, but there seemed to be some discrepancies. Yes I did do a search before posting  ;)
Does anyone have a list of which calipers and forks are the same or similar?
I read on a different post that the 550 calipers have different hole spacings to the 750, but some 550 K5ish legs I have, have the same casting no as the ones on my K2 750   ( 341 I think? )
I'm interested in doing a dual brake setup for my 750 for a period cafe racer type resto and thought I may be able to use the caliper.
Offline puppytrax
Re: Calipers & Forks
« Reply #1 on: November 11, 2006, 07:46:50 PM »
I have a set of "341" casting forks; they came off a CB550, and have the dual mounts. The OEM CB550 fender fits, and so does a single-brace fender from a 750 (don't know what year/model)...
I also have a *long* fork lower, which is a single disk setup, and has the same caliper/fender mounts as the stock CB500/550, but is about 1 1/2" longer between the mounts and the dust seal/wiper...I don't know what this one is from (eBay purchase)...
I also have a CB750 front disk; it is ~3/4" bigger than a CB550 front disk, but will bolt up to the same wheel.
« Last Edit: November 11, 2006, 07:49:52 PM by puppytrax »
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #2 on: November 11, 2006, 11:03:39 PM »
The 1972ish  CB450 forks will slot right into the CB750 trees. They can be serviced where the CB750 forrks must be tossed when worn. I am no Guru on the valving for the shock damping but they seem ok.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
