Author Topic: Looking to clean the carbon out of oem Honda mufflers;what works good ?  (Read 4572 times)
Offline grcamna2
I have never cleaned any carbon out of oem stock mufflers,they have a lot of different chambers inside them and sometimes I pick up a used oem muffler that's been sitting for a while and want to put it back into service that has it's own mix of rust and carbon.
What do you use to get the maximum amount of 'junk' out of these, liquid to melt the carbon w/ a combination of tapping and rubber hammer ?  ideas please
« Last Edit: March 19, 2016, 10:11:49 AM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline grcamna2
bump
Offline strynboen
why?  its a 2 stroke idea to klean exh.
    .no  one done it on 4 str bikes..they only blow in the exhosts.
..2 stroke sucks back chok wave..so dirt  and rust is a problem going back in the engine..and they build up a large carbon vall in the port/tube..vho can block it total up....so they need a  causic soda bath to loosen up..or burn them dry..and shake all loosen stuff aut
i hate all this v-w.... vords
Offline dusterdude
100 mph blast down the interstate
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
yep. pull the baffles if you can.
Offline grcamna2
 ;) That's certainly in my plans  :D ,although the baffles aren't removeable.  I had my powder coating guy shoot the big sandblaster into the inlet side of a muffler I brought to him a year ago before he PC'd it and I was able to shake all the sand out later,I think it cleaned a little rust out.
« Last Edit: March 28, 2016, 03:55:24 PM by grcamna2 »
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
grcamna2 ; Most folks don't think about it but you do bring up a good question ! All the exhaust soot (rich running),rust (from condensation) and so forth, "Does" create a slowing of the air flow. Being able to remove as much of the build up as possible would help our bikes breathe ! Hope maybe one of the more "tech type fellows" here will chime in on this subject. Thanks for thinking !    ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
Offline grcamna2
I'm wondering if pouring a strong special liquid into them would melt some of the carbon? or tend to damage the baffles(if they have fiberglass packing?) somehow ?
« Last Edit: March 20, 2016, 12:29:27 PM by grcamna2 »
Offline strynboen
rust can close the small holes in the expansion tube part,, but does Honda use labyrent  type  or expansion.
.no idea,,,,but both make the back pressure stronger
Offline grcamna2
bump
Offline spotty
Re: Looking to clean the carbon out of oem Honda mufflers;what works good ?
« Reply #10 on: March 28, 2016, 04:26:17 AM »
on two strokes we used to use an unsafe concentration of caustic soda in boiling water which used to do a grand job of shifting the carbon. don't know if it would work on 4 strokes as the carbon may be 'drier' for want of a better word.
two stroke carbon seems to stay softer maybe due to the oil in it whereas 4 stroke carbon seems drier and harder so i don't know if the caustic soda would do the trick. give it a try and see maybe
on the two strokes, we'd pour a canister of soda down the neck of the chamber and then pour boiling water in afterwards, dangerous and probably stupid
just be very careful, it will blind you and it will take skin off. always add soda to water not the other way round, it will spit back, wear goggles, wear gloves etc
i blame Terry
Offline grcamna2
« Reply #11 on: March 28, 2016, 06:16:50 AM »
The engine that this muffler came off must have been burning oil so i poured gasoline into both ends and shook it real well then tried to pour-out as much as possible & then let it dry out over the warm weekend we just had.I just gave the muffler to my PC guy who will use the large sandblaster into the inlet a little.
What is caustic soda,same as baking soda?  unsafe to use?
« Reply #12 on: March 28, 2016, 10:53:41 AM »
Is caustic soda actually lye? ie sodium hydroxide.
Would a radiator shop dunk it for you? Would that affect the finish?
Offline grcamna2
« Reply #13 on: March 28, 2016, 01:08:38 PM »
bump.
I'd like to know.
Offline RevDoc
« Reply #14 on: March 28, 2016, 01:31:01 PM »
bump.
I'd like to know.
The answers are yes, yes, and maybe, depending on the solution.  ;)
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Offline grcamna2
« Reply #15 on: March 28, 2016, 03:53:59 PM »
bump.
I'd like to know
Then it would be considered to me that I could stand up the muffler vertically w/ the inlet side facing up and plug-up the outlet on the bottom w/ a type of rubber plug and then try to arrive at a certain strength to mix the caustic soda solution(and the correct set-up and procedure w/o blowing myself up  :o  :D)pour it inside until full? and then wait for a while and then rinse? I would appreciate a 'walk through' of procedures on this one but I hope I have the basics of a plan with it. Have any of you done this before ? if so please PM me some details if you like.
This muffler has had years of exhaust soot,burning oil,rust,etc. and I'd like to get it 'clean as a whistle' for best performance.  ;)
« Last Edit: March 28, 2016, 04:00:54 PM by grcamna2 »
Offline RevDoc
« Reply #16 on: March 28, 2016, 08:46:19 PM »
grcamna, if you want to try this approach, I would NOT recommend using any caustic soda aka lye
crystals unless you have full chem-lab safety gear to protect your eyes & skin. Lye making contact with water can react violently and fly right out in your face. :o
You could try pouring boiling water through first to soften & rinse some material out and warm the metal for a quicker reaction then use a hair-clog type drain cleaner. It is also corrosive to some extent but, not to the extreme of full strength lye.
Dana
'78 CB550K--Angie
Offline spotty
« Reply #17 on: March 29, 2016, 03:34:30 AM »
told you it was dangerous and stupid, but thats me all over.........maybe have a few drinks first to add that 'edge'
i blame Terry
Offline grcamna2
« Reply #18 on: March 29, 2016, 05:03:49 AM »
I gotcha  ;)
I think I'd want to rinse it out after lets say.. 20 minutes of sitting after using the drain clog cleaner w/ some more hot water.
Offline RevDoc
« Reply #19 on: March 29, 2016, 07:54:41 AM »
I gotcha  ;)
[/quote]
Good choice! Even then you should use safety goggles. We are only blessed with one set of eyes in this life.  ;) And do watch for spills on any chrome, as the drain cleaner will discolor it.
Dana
'78 CB550K--Angie
« Reply #20 on: March 29, 2016, 11:42:19 AM »
Yeah, it's called CAUSTIC for a reason.
Offline brewsky
« Reply #21 on: March 31, 2016, 04:05:37 AM »
Radiator shop?
They "boiled" out a whole gas tank for me (had been sitting full of old gas for years), with rust, sludge and whatever else, and did a super job.
I told them not to worry about the paint.
When I asked them what they used to soak it in, he said he didn't know, just some "white powder mixed with water"?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline RevDoc
« Reply #22 on: March 31, 2016, 06:37:27 AM »
Radiator shop?
The "white powder" may well have been TSP aka trisodium phosphate. It is used quite often for cleaning in industrial applications. Have seen it used in bike shop ultrasonic tanks and does a good job but, does discolor aluminum carbs.
Dana
'78 CB550K--Angie
Offline MoMo
  • Ride like you're invisible
« Reply #23 on: March 31, 2016, 07:13:53 AM »
Unless the interior of the exhaust is super dirty it seems to me that any "performance" increase would be insignificant, especially considering the possible danger to skin, eyes and the chrome of the pipe.  Larry
