Author Topic: Slick Trick for Wheel Bearing Removal  (Read 1578 times)
Offline Popwood
« on: March 22, 2016, 03:23:41 PM »
I didn't see this in a forum search but perhaps it has come up. If so, just ignore.
So the trick is to use a concrete wedge bolt to remove wheel bearings. I knocked out my 750 rear wheel bearings this way this afternoon and it was sooo easy. The link below is a video showing how it's done. So simple.
I picked up a 3/4" wedge bolt at the ACE store earlier today that did the trick. The video mentions grinding back the nipples on the bolt sleeves. Don't overdo that, as I did. Had trouble getting the mushroom head sleeves to tighten in the bearing. My work-around was slipping two pieces of aluminum flashing between the sleeves and mushroom head. Worked like a charm. Also, this removal method has zero risk of damaging the inner spacer between bearings.
Check it out if you haven't seen this.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline CB650CPastor
Re: Slick Trick for Wheel Bearing Removal
« Reply #1 on: March 22, 2016, 06:02:08 PM »
Good way to get it out as long as you're not going to reuse it. Never hammer the inner race.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #2 on: March 23, 2016, 06:19:33 AM »
I was all excited to try this when I did my bearings last year... just kept slipping out.
I ended up using a long punch and a screwdriver to wedge in there.
--Evan
1975 CB750K "Rhonda"
Offline Popwood
« Reply #3 on: March 23, 2016, 08:29:25 AM »
The hammering is pretty straight forward. I used a two pound hammer striking a short length of 1/2" galvanized pipe. The first bearing took 8 or 10 blows, the second only five or six. You are striking the bolt, not the bearing itself. As such, its driven straight out and you don't have to fuss with inside spacer, trying to shift it enough to get a punch or drift on the edge of the bearing.
Current Rides:
1975 cb550K
1975 cb750K
Past Rides:
1988 400 Hawk
Offline Popwood
« Reply #4 on: March 23, 2016, 08:34:22 AM »
I had trouble with it not grabbing at first, too. It only worked when I inserted the thin strips of aluminum flashing between sleeve and mushroom head. I think this became necessary because I ground off too much of two nipples on the sleeve. I ground them all the down to flush.
Current Rides:
1975 cb550K
1975 cb750K
Past Rides:
1988 400 Hawk
Offline evanphi
  • Apparently I'm an
« Reply #5 on: March 23, 2016, 08:50:39 AM »
You still wouldn't want to re-use the bearing, as it would be potentially causing nicks from the inner race hitting the balls when you hit the pipe.
--Evan
Offline Popwood
« Reply #6 on: March 23, 2016, 09:16:41 AM »
No, you wouldn't want to reuse the bearing. In most cases, I suspect, the bearings are being removed and replaced with new ones. My 40 year old bearings are only good paperweights now.
Current Rides:
1975 cb550K
1975 cb750K
Past Rides:
1988 400 Hawk
Offline Powderman
« Reply #7 on: March 23, 2016, 09:26:30 AM »
So this method would be used by who? Some one who doesn't have a socket set and an extension? I also want to know how he got the first bearing out?
Offline evanphi
  • Apparently I'm an
« Reply #8 on: March 23, 2016, 10:02:17 AM »
Same method. With the spacer in between the two bearings it is harder to get a socket in there.
--Evan
Offline henrikm
« Reply #9 on: March 23, 2016, 10:45:33 PM »
Different video showing the first bearing
I have used this method a few times and it works really well. Think it is crucial to get the right size of anchor bolt to make it grab, think the one I'm using is 16mm.
« Last Edit: March 23, 2016, 10:48:12 PM by henrikm »
