SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
1975 CB750F with oil leaks.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1975 CB750F with oil leaks. (Read 1290 times)
kaptainkid1
Enthusiast
on:
April 13, 2016, 01:23:31 PM »
I have a 1975 Honda CB750F super sport and I have few oil leaks around the bottom end.
Since the bike is stock and more than likely all original parts how often does the Oil line leak?
It seems the oil is leaking from the Oil Lines to sump reservoir.
How often do these lines fail and need to be changed? I know they're 41 years old. Should I just buy ebay used ones? or buy news ones?
I feel the oil can be leaking from other place too. I haven't track them down since the leak is very minor. No appreciable oil lost during fluid changes.
<img src="http://i.imgur.com/6pXmHQX.jpg?1" title="source: imgur.com" />
Last Edit: April 13, 2016, 03:30:25 PM by kaptainkid1
Logged
1975 Honda CB750F Daily Rider
1974 BMW R90S Barn Find
1995 BMW R1100GS Dual Sport Daily
1996 Triumph 900 Adventurer Bobber
flybox1
My wife thinks I'm a
Really Old Timer ...
Re: 1975 CB750F with oil leaks.
Reply #1 on:
April 13, 2016, 02:21:11 PM »
you can have new braided stainless lines made. might help, or replace the o-rings where they attach to the case.
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
Jerry Rxman Griffin aka MuthaF'er
This MuthaF'er is getting to be a
Bought her new 4/75
Reply #2 on:
April 13, 2016, 02:26:24 PM »
I'd go for 2 new O-rings at the fitting. Make sure you're not getting drips from the clutch cover instead or the seal for the kick starter. The part bolted to the engine, not it's chrome cover.
Logged
As of today 3/13/2012 my original owner 75 CB750F has made it through 3 wives, er EX-wives. Free at last. ;-)
kaptainkid1
Enthusiast
Reply #3 on:
April 13, 2016, 03:33:49 PM »
Replace the o-rings first before buying new ss braided lines. Which i've priced at $120 on ebay. Ok I'll do that first.
So these lines are very strong then? It seems they're covered with cloth braid and I"m guessing rubber tube?
Logged
HondaMan
Someone took this pic of me before I became a
...not my choice, I was nicknamed...
Reply #4 on:
April 13, 2016, 03:50:31 PM »
When they leak, it is usually caused by someone wrestling them out of the frame - they then leak near the crimp fittings. Sometimes the wrestlers have actually split the hose(s), working them so hard.
Where is the oil showing up on the bike?
Logged
See
SOHC4shop.com
for info about the gadgets I make for these bikes.
Link to Hondaman Ignition:
http://forums.sohc4.net/index.php?topic=67543.0
Link to My CB750 Book:
https://www.lulu.com/search?adult_audience_rating=00&page=1&pageSize=10&q=my+cb750+book
Link to My CB500/CB550 Book:
https://www.lulu.com/search?sortBy=RELEVANCE&page=1&q=my+cb550+book&pageSize=10&adult_audience_rating=00
Link to website:
https://sohc4shop.com/
(Note: no longer at
www.SOHC4shop.com
, moved off WWW. in 2024).
JWExperience
Guest
Reply #5 on:
April 20, 2016, 03:13:23 PM »
I had a set start leaking at the crimps. I found a local place that just crimped new stainless braided lines for like $15 after I cut the old crimps off.
Logged
70CB750
Labor omnia vincit improbus.
Northern Virginia
Reply #6 on:
April 21, 2016, 04:54:51 AM »
^^^That^^^
With a bit of luck, somebody can cramp new lines on for you, they carry 0 pressure, even clamped on rubber hose would work.
Logged
kaptainkid1
Enthusiast
Reply #7 on:
April 21, 2016, 10:46:08 PM »
yeah i've decided to put on new braided ss lines.
Logged
b1jackson
Hot Shot
Reply #8 on:
June 20, 2016, 05:18:21 PM »
I just bought a bike with a similar leak. It collects on middle of the swing arm and puddles at the lowest point near the chain tightener on the left. Any idea what size the o-ring is before I dismantle? I don't thing mine has ever been off before so I don't expect it's been roughed up.
Logged
Old Honda Rescue Centre
ohrc_vintagemoto on Instagram
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
