Author Topic: CB750 ignition switch  (Read 2727 times)
Offline Sgt.Pinback
« on: May 30, 2016, 03:17:57 AM »
Hi,
have three different ignition switches, all with roung plug.
I assume the one on the left (with "OFF" upside down) is (late) KO. Can you identify?
Doc, I love a motorcycle!
Offline Johnie
Re: CB750 ignition switch
« Reply #1 on: May 30, 2016, 04:59:38 AM »
A true KO switch will be recessed at the key. Those appear to be for the K1.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Sgt.Pinback
« Reply #2 on: May 30, 2016, 06:11:17 AM »
Not all KO had the recessed ignition switch.
The three in my photos are different to each other:
left has "OFF" upside down
middle has "OFF" upright down, shorter thread and a different ring
right has "Ignition" instead of key number (= after market?)
Can you please check on your K1 and on your K3?
or anybody else with K1 -K6.
« Last Edit: May 30, 2016, 06:17:01 AM by Sgt.Pinback »
« Reply #3 on: May 30, 2016, 06:20:54 AM »
 I always believed the one on the right to be aftermarket, I'm curious to see if that's true also. The locating washer with the tabs is a rare bird too.  my K4 might be original, i'll check it later this morning.
« Last Edit: May 30, 2016, 06:22:53 AM by Don R »
Offline CycleRanger
  • No comment about being an
« Reply #4 on: May 30, 2016, 06:31:20 AM »
Imho, the one on the left is original. The other two are repops.
Offline Johnie
« Reply #5 on: May 30, 2016, 07:27:07 AM »
If you got a KO without the recessed then it's a real late KO built after they ran out of the recessed and started to put the K1 switch on. I will check mine for you and get back to you.
Oshkosh, WI  USA
Offline Sgt.Pinback
« Reply #6 on: May 30, 2016, 08:01:02 AM »
Maybe, but
IMHO the one in the middle is an original as well, at least has a genuine HONDA key and key number.
Offline CycleRanger
« Reply #7 on: May 30, 2016, 08:09:31 AM »
Maybe, but
It may be a genuine Honda part but it's not K0-K1 era.
It's the apparent NXXXX (if I'm reading it correctly) code that makes me think it's at the very least a later '70's replacement.
« Last Edit: May 30, 2016, 08:28:35 AM by CycleRanger »
« Reply #8 on: May 30, 2016, 08:20:08 AM »
 I agree the right is likely aftermarket. The middle switch could be K2, they should all be round plug...
Offline goldarrow
  • one day, i'll be an
« Reply #9 on: May 30, 2016, 08:48:41 AM »
I think left is original from 70's, middle is Honda repro, right is aftermarket
CB550 K0
Offline Sgt.Pinback
« Reply #10 on: May 30, 2016, 09:02:44 AM »
Middle is number N2738.
The one in the middle looks like this one:
http://www.ebay.de/itm/Honda-CB-750-Four-K0-K1-K2-Zundschloss-Original-35100-303-007-/322030553016?hash=item4afa8447b8:g:yXEAAOSwLVZV6C9k
I trust M. Döring (sandguss) that its a genuine HONDA switch 35100-303-007
But actually cant find 35100-303-007 in my parts book.....
Here K1, K2 should be 35100-313-003
Being more and more confused
« Last Edit: May 30, 2016, 09:23:46 AM by Sgt.Pinback »
Offline CycleRanger
« Reply #11 on: May 30, 2016, 10:46:00 AM »
That PN is obsolete and likely a combo code to consolidate part numbers.
In the late '70's and onward Honda would create codes for older parts that were essentially identical.
That switch could be used in a several different bikes, not just 750's.
For example PN 35010-303-003 was superseded by 35010-315-017 which is the current PN for a couple of dozen bikes prior to '71.
That -007 PN may have been the European number, same number later rev.
« Last Edit: May 30, 2016, 10:51:53 AM by CycleRanger »
« Reply #12 on: May 30, 2016, 02:09:44 PM »
  Lots of Honda's used that early round plug. Here is a list a guy compiled for his E-bay auction. Some of the 450 switches were even recessed and guys try to sell them as original sandcast to unsuspecting folks.  http://www.ebay.com/itm/Honda-NOS-CB750-750-Key-Ignition-Switch-175-125-350-450-35010-315-017-/221276238289?hash=item33851771d1:m:mu2JcofwJe3JgvI198rVvZQ&vxp=mtr
Offline Sgt.Pinback
« Reply #13 on: May 30, 2016, 10:30:35 PM »
Thanks.
 So this one looks as mine on the right.
So all of my switches seem to be genuine switches but I still do not know which one came with which 750.
I assume: (late ) K0 - K1- K2 from left to right
