Author Topic: 1971 CL350 Craigslist find  (Read 24467 times)
Offline Bankerdanny
  • Endeavor to persevere
Re: 1971 CL350 Craigslist find
« Reply #125 on: October 18, 2016, 09:10:35 AM »
Definitely. I am also fortunate to have the world's best brother-in-law, who hooked his trailer up and drove 60 miles at midnight to come and get me and the bike.
Offline Scott S
« Reply #126 on: October 22, 2016, 01:57:03 PM »
Clutch push rod seal it is! Oughta be an easu enough fix. I'll get one ordered.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline grcamna2
« Reply #127 on: October 22, 2016, 03:52:49 PM »
The Best way to install that seal is to assemble the cases and w/ it crimp it down tight.The seal can be installed w/o splitting the cases but much care needs to be taken to install it without deforming it plus pushing it in far enough.. Make sure the seal and cases are bone dry.
75' CB400F/'bunch o' parts'
Offline Scott S
« Reply #128 on: October 22, 2016, 04:39:52 PM »
 Oil seal ordered. Only $8 shipped and genuine Honda. I'll polish up the pushrod and use a light smear of Yamabond when installing the seal.
 I think I'll make one of those retainers for the seal, too. Apparently, this is a pretty common problem!
'71 CB500 K0
'81 Yamaha XS650
Offline grcamna2
« Reply #129 on: October 22, 2016, 04:53:54 PM »
if you use the "light smear of Yamabond" only put it on around the outer part of the seal as a small finishing bead (wait 24hrs. before you start it)'after' you install it dry to the bare aluminum hole;maximum friction(nothing slippery) to keep the seal in.The old seal that came out is undersize/shrunk from age which is probably why it popped out.
Honestly the best way is to split the cases so you can crimp that new full size dia. seal down tight between them;if that seal comes out again while you're underway on a ride it can be catastrophic.  :o seized engine and lot's of oil on the back tire.. and i know you'd rather not wipe-out at speed.  ::)
« Last Edit: October 22, 2016, 06:50:25 PM by grcamna2 »
Offline MoMo
  • Ride like you're invisible
« Reply #130 on: October 22, 2016, 06:18:00 PM »
I had a similar problem Scott.  Was fine and then out of nowhere an  oil leak-wound up being the shift shaft seal had come out of its seat in the motor. Cleaned it up, used a bit of Hondabond around the seal and it was fine ever since...Larry
Wow,  brain frat.  I meant clutch push rod seal....Larry
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #131 on: November 30, 2016, 12:53:11 PM »
    I saw a deal on a CL350 once, and it also was a '69 and the price was right (though I don't remember how much now), so I made arrangements to meet the guy, where the bike was and was ready to take it off of his hands. He told me where to meet him and I was there, "Johnny On The Spot" and I waited, and waited.......... and waited..........Then I tried to get him on his phone, and I called... and called..
can you see where this was going? yeah, no where! I had been stiffed!! What a pain, and it was local too! I would have REALLY been irate, if I had driven for an hour or so. Anyway...... >:(
Member # 1969
