Author Topic: 71 CB750K Turn Signal Problem - Maybe Flasher Unit??  (Read 1799 times)
ILLBlueRider
« on: May 31, 2005, 02:56:32 PM »
Finally got my 1971 CB750K running good so I took for a spin.  Hit the left turn signal and blew the main fuse.  It worked great a few days ago.  Refused & checked the right blinker....worked great.  Hit the left blinker & she blew again.  Will a flasher unit work on one side and not the other??? Or do you think I just have a direct wiring short somewhere??
Are these flasher units still available??  Thanks for any advise you can give me on troubleshooting this electrical problem...
Offline mcpuffett
Re: 71 CB750K Turn Signal Problem - Maybe Flasher Unit??
« Reply #1 on: May 31, 2005, 03:20:47 PM »
yep you can still get the flasher units ,but a lot of folks get the car ones because they are cheaper ,and yes a flasher unit can work great on one side and not the other? check your wiring make sure there is nothing amiss ,get another flasher unit and try again  :-\  mick.
Offline cb650
« Reply #2 on: May 31, 2005, 03:53:35 PM »
sounds like a short on the left side.  Bet its in the rear.
                     Terry
Offline mrbreeze
  • Not your average
« Reply #3 on: May 31, 2005, 06:58:21 PM »
I just fixed mine a couple of months ago. they weren't popping fuses but they wouldn't blink till I revved up so I took all signal lenses off,cleaned all sockets,replaced flasher with $2 unit from parts house.All works good now.It is possible to have a short in flasher but check wiring as other poster suggested.Lift seat and check wiring to rear sigs. It should'nt be anything expensive to fix.
MEMBER # 257
