Author Topic: Gear Lever  (Read 1814 times)
Offline Speza
Gear Lever
« on: September 19, 2016, 04:35:30 AM »
My gear lever keeps falling off.
I have replaced the clip and the washer, but it still happens.
Any ideas beyond drilling a hole in the shaft and sticking a pin in?
Offline Scott S
Re: Gear Lever
« Reply #1 on: September 19, 2016, 05:02:29 AM »
 Clip and washer?
 What bike?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: Gear Lever
« Reply #2 on: September 19, 2016, 05:04:39 AM »
Yes- that should be a pinch fit with a bolt on the spline shaft.
Offline Speza
Re: Gear Lever
« Reply #3 on: September 19, 2016, 07:54:25 AM »
Ooop's should have mentioned bike, 400/4 F
Offline Speza
Re: Gear Lever
« Reply #4 on: September 19, 2016, 07:56:24 AM »
It is a 400/4 F, the gear lever is located on a shaft, then links to the splined bit with a couple of ball joints.
Re: Gear Lever
« Reply #5 on: September 19, 2016, 08:01:50 AM »
Offline 01Thomas
Re: Gear Lever
« Reply #6 on: September 19, 2016, 02:08:19 PM »
On my 400F I had the same problem. I solved it by drilling a hole through the shaft in the groove where the clip goes - and then I assembled iut with a splitpin instead of the circlip. Looked like a factory job.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline Speza
Re: Gear Lever
« Reply #7 on: September 20, 2016, 12:53:35 AM »
Thanks for that.
The picture has given me a bit of a clue.
Item 22 that fits on the splines, is the wrong way round, the ball joint is on the inside, I will try reversing it.
Cheers
Offline Speza
Re: Gear Lever
« Reply #8 on: September 20, 2016, 12:54:19 AM »
Yes, that is my last resort.
Cheers
Offline Bodi
Re: Gear Lever
« Reply #9 on: September 20, 2016, 01:44:56 AM »
If the shaft groove is so badly worn that the clip falls off, you can try making it a bit deeper with a "jewellers" edge file or thin saw blade. Drilling and tapping the shaft end for a retaining washer and screw is an option, that would probably look better than a cross drill and small split pin? The part with the pin (50641-377-000B) is basically unobtainable new, and used 400F parts are uncommon - plus their quality is not reliable. You can try Ebay...
Online scottly
Re: Gear Lever
« Reply #10 on: September 20, 2016, 08:52:22 AM »
Make sure the clip is installed the right way; they have one side with rounded edges and one side with sharp edges. The side with sharp edges should be facing out.
