Author Topic: Cb350f fresh top end smoking like nuts!  (Read 16512 times)
Re: Cb350f fresh top end smoking like nuts!
« Reply #75 on: October 25, 2021, 07:31:26 PM »
Quick update everyone. I installed the Honda NOS rings on the CI pistons, had the machine shop measure piston to to bore clearance and set a fresh hone. Got the bike back together, fired right up ran great and didn't smoke until it got to operating temperature and it started smoking again. I rode the bike for 10 miles varying throttle and engine loads and the smoke continued. It's not smoking as heavily as it did before but I think that's b/c we put 100 miles on the previous build and the head pipe and muffler had filled with oil that I cleaned out during the second tear down. Another odd item is the bike's valve cover/crankcase vent tube is pouring out smoke, almost more than what's coming out of the exhaust pipe. I will pull the plugs today to confirm all 4 are oil fouled then I think it's time for a leak down test to see if the issue is in the head.
The machine shop looked at the CI rings and they appeared to have a nice seal wear on them. We also installed another new set of valve stem seals just in case that was the issue. The bike has plenty of power (as it did on the previous build) so I'm thinking it's in the head. Also the bike runs great and doesn't smoke when it's cold. Once it heats up it smokes, won't idle and has heavy hesitation throttling up but has plenty of power. I think the poor idle and hesitation is from the the motor oil fouling the plugs at low rpms.
Just throwing out all that I can to this group to assist anyone with this same issue. This is crazy that we can't figure out the issue. I will keep posting updates as they happen.
This one sure is odd(!). Do you know the valve stem-to-guide clearance in the head? It is very tight on this particular engine, due to the small size of the valve stems. During the middle 50% (or so) of valve travel, this engine's geometry will push the valve stem sideways by its max clearance, which often exceeds the speed (or flex) of the valve seals' material to keep up. I'm kinda wondering if this might be the culprit? It would rear its head much more when warm than when cold, and would cause high crankcase pressures and 'wet' crankcase exhaust fumes. Even one cracked valve guide would be enough to cause it. I have seen a CB400F head with a hairline crack in the head, radiating from a valve guide (exhaust), which made a real nasty mess of one exhaust pipe at the head, and it smoked out the crankcase hose.
Offline SquierA
« Reply #76 on: October 26, 2021, 10:55:42 AM »
A guy posted a youtube video this summer with the exact same bike and issues, literally 2 top end rebuilds/teardowns with new pistons, rings and bore with the same results...smoking heavily. The valve guides were the culprit and he did a great job showing the problems in the video with a bore scope and head tear down.
I never had the valves, guides or head inspected and measured for wear. I just had the shop clean everything and install new valve stem seals. Stupid on my part. This bike had 23K miles on the clock when I bought it and the motor had been beaten up pretty bad.
I will take the head to a very reputable machine shop that specializes in vintage Honda engine restorations. I already spoke to the shop owner and he will inspect and measure the head, valves and guides. He's back logged about 2 weeks and I will post an update once he's completed his inspection.
Offline Tim2005
« Reply #77 on: October 26, 2021, 03:51:04 PM »
Do you have a compression gauge? It would be useful to see what numbers you are getting- your comment "Another odd item is the bike's valve cover/crankcase vent tube is pouring out smoke, almost more than what's coming out of the exhaust pipe" makes me wonder, as the only time I have seen a small sohc4 engine (400f) breathing that badly it was due to low compression from broken piston rings. I've had very worn valve guides too in the past but they haven't really caused running problems.
Offline SquierA
« Reply #78 on: October 30, 2021, 09:33:32 AM »
Quick update here. I took the head to a different machinist for a second opinion and watched him take it apart and inspect the valves and guides and everything was well within spec. I pulled the cylinders, pistons and rings and brought them to him as well and he is inspecting them for piston to cylinder clearance and all other specs to see if he can find the issue. As of now the solution is still not found. On a side bar we looked at the original pistons and rings and they don't indicate any issues with the severe oil pooling on the top of the pistons. I'm starting to lean towards the CI pistons being the culprit and am wondering if I need to order NOS Honda pistons at .75 and have the cylinders rebored to fit them. I will post another update soon.
Offline grcamna2
« Reply #79 on: October 30, 2021, 10:05:11 AM »
Do the valve guides check-ok ?
75' CB400F/'bunch o' parts'
Offline SquierA
« Reply #80 on: October 30, 2021, 01:44:32 PM »
The valve guides were well within spec. No issues there. No oil leaking down from the oil o ring under the guide either. The head and it's components checked out fine.
Offline SquierA
« Reply #81 on: November 16, 2021, 06:18:38 PM »
Another update. I shipped the cylinders, pistons and rings to Utah Crankshaft & ShortBlock and they measured the piston skirt to cylinder clearance and all 4 cylinders measured differently and were at the high end of being within the maximum wear limit. The machinist recommended 0.75 over NOS pistons and rings which I ordered today on ebay. Utah Crankshaft will rebore the cylinders to the NOS Honda pistons and we will see if that cures the smoking problem. I will post an update once I have the bike back together and running again.
Offline grcamna2
« Reply #82 on: November 16, 2021, 06:46:56 PM »
That will definitely cause it to smoke.
I'm glad you found NOS OEM oversize pistons and OEM piston rings.
« Reply #83 on: November 17, 2021, 04:49:32 PM »
One of the largest problems I see with these engines after a 'reputable' machine shop worked on them is: most machine shops INSIST on using non-Honda measurements, substituting [some other measurement] instead.
Honda uses 0.0004"-0.0008" piston clearances in this (and CB400F/500F/550F) engines, This is usually 1/2 to 1/3 of what most (lazy, IMHO) machine shops consider to be "in spec", and your experience echos this, loudly. Most shops work in the 0.0020"-0.0025" arena for "clearances" without looking them up. Recently I helped another rider to fight his way through this problem with his machine shop when they insisted the piston bores were "...well within spec.." (this one in Canada) until the bike owner forced them to go and look it up themselves while he waited (he is also a cop...), which they did. When they came back, hat-in-hand, they then agreed to re-bore it to the CORRECT tiny clearances with new (next-step oversize) pistons, and it worked fine the next time...
Offline SquierA
« Reply #84 on: December 15, 2021, 02:50:09 PM »
Another update here...
The previous machine shop had bored the cylinders to match the CI pistons and the piston to cylinder clearances were measured by Utah Crankshaft & Cylinder at #1 .00250, #2 .00375, #3 .00375, & #4 .00350.
I ordered the NOS .75 over Honda pistons and Utah Crankshaft re-bored the cylinders to match and now the clearances measure .00175 for all 4 cylinders. The factory spec is .0004-.0016 which means that technically the new bore is out of spec. I'm a little frustrated the shop didn't bore them within the spec since I provided it to them however they are very confident the previous bore was way out of spec and sloppy and feel this new set up will seal up well and the engine should not smoke. I will say the new bore and hone work are the nicest I've seen. There are no score marks, glazing or odd looking items in the cross hatch or cylinders. I'm very impressed with the visual look of the re-bore and hone.
I also obtained NOS .75 over Honda piston rings and will install this fresh top end over the holidays and will post another update when completed.
Happy Holidays Everyone!
Offline grcamna2
« Reply #85 on: December 15, 2021, 03:14:45 PM »
Non-Powersports machine shops Piss Me Off:I have had Many situations like this..  ::)
I hope you have good experiences this time.
« Reply #86 on: December 15, 2021, 04:40:18 PM »
^^ Yeah. what he said...
I get a lot of top ends from these bikes, just to have my machine shop bore them correctly and install new guides (when needed) correctly. It's alot of postage, but those owners could not find the right shop, either.
Makes me sad. :(
Offline hawaiikid
  • 1975cb400f
« Reply #87 on: December 16, 2021, 11:27:02 PM »
I can testify to Hondamans (Mark) clearance measurements. Local shop messed my bore up so I sent them to Mark and have no problems with smoke on my Cruzin Image pistons and rings on my 466 big bore cb400. I now have over 800 miles on new top end and no sign of smoke or any oil blowing out my exhaust. One happy camper here! I wonder if there should be a list of shops that can successfully do the bores on the smaller bikes as it seems that I've noticed a lot of smoking issues on the smaller fours.
« Reply #88 on: December 17, 2021, 09:32:47 AM »
My CI pistons my CB750 K2 has are oversize +0.50mm pistons. Bore clearance on the loose side for CI.
I read about CI pistons on this forum and told the shop to bore max 0.025mm/ 0.000984251".
No smoking. I have another cylinder and new set of pistons. Tighter on them, think  0.02mm/0.000787401"
Forged pistons have the higher numbers, 0.05- 0.06mm.
A real waste that the shop could not do it right. Maybe tricky to find old OK sleeves to do another try on.
« Last Edit: December 17, 2021, 09:34:44 AM by PeWe »
« Reply #89 on: December 17, 2021, 04:48:32 PM »
I have been doing the 350F engines at 0.0004"-0.0006" clearance for a long time. Recently I did my own 750 to 0.0006" clearance on 3rd oversize pistons and the increased power and smoothness surprised me: it runs cooler, too. Top speed is higher as well. I also reduced the crank main bearing clearance to 0.0006"-0.0008", which is at/below Honda's spec, but I figured my crank was well-polished at 131k miles. That made the oil pressure almost 10 PSI higher on the hot engine, too: it used to run around 45-50 PSI at 2500+ RPM (and 5-7 PSI at hot idle, 900 RPM), now runs above 50 PSI at speed and around 10 PSI at hot idle. I took a long time to break it in, though, which was the tradeoff for going so tight. I'm doing another 750 like that now for one of our members.
Offline SquierA
« Reply #90 on: December 17, 2021, 05:29:15 PM »
HondaMan I didn't know you offered this service or I would have reached out to you for the bore work I just had completed. In my restorations I most concerned about getting it done right and preferably the first time. Live and learn.
« Reply #91 on: December 17, 2021, 06:23:10 PM »
After I [painfully] "trained" my local machine shop to do it my way, they haven't messed any of these up. They have been good to work with, prices seem to be on-par with those I hear about here in the forums, around the US. The postage to-from is killer, though, especially since the Kung Flu thing started! I recommend Fedex (and insurance) for partial engines (others for whole ones) as the one who has damaged the least number of these shipments so far. UPS has virtually destroyed 2 engines and several top-ends that were sent, although one of the engines was a 550 in a simple cardboard box: when the UPS guy carried it in (!) and set it down, it rolled over, upside-down, because the box was essentially round by then. There were lots of broken fins and a dented-in clutch cover on that one. :(
« Reply #92 on: December 23, 2021, 07:25:07 AM »
Makes me sad. :(
How are they not installing guides correctly? Not heating the head? Not bead blasting the carbon off? It's a pretty simple operation.
« Reply #93 on: December 23, 2021, 12:11:15 PM »
Makes me sad. :(
What seems to happen the most is: they severely over-clearance the valve stems after installing the guides (in my case, I install the gudes first, then have them do the work to match the guides to the seats with their Sioux and Serdi machines). I don't know where some of the shops get numbers like 0.003"-0.004" for 'correct' valve stem clearance, but it seems to be a popular number. These guides use half that figure, and tighter with bronze. I went tighter yet on my own engine in 2013, using Honda's old (1970s era) racing specs of 0.0010" intakes and 0.0016" exhausts in bronze guides, and it loves that.
Even my car engines use 0.0024" or less, so their work leaves me puzzled sometimes? How could they do it over an over and still be in business?
« Reply #94 on: December 24, 2021, 10:03:58 AM »
Makes me sad. :(
I install first than have them honed using a Serdi pilot to check and achieve proper clearance. Yunick said .0025 for intake and .003 for exhaust for endurance racing automobiles and he admitted that that was loose. It is certainly loose for back then and way too loose for CB engine. I'm lucky as the shop I have used for many years works on motorcycle engines almost exclusively.
 .003 to .004 is worn out IMO.
« Reply #95 on: December 27, 2021, 06:12:38 PM »
Makes me sad. :(
Ah, yes, "Smokey" Yunick...I forgot all about him and his columns. I used to read his stuff until I got my first job in a Honda shop, under a master mechanic who knew these engines. He told me to "...forget everything you learned from Hot Rod magazines, the bikes are different..." on my first teardown under his guidance. Later on I learned he was dead right!
Offline SquierA
« Reply #96 on: February 03, 2023, 10:03:18 AM »
Sorry for the long delay. I finished up the bike in June and stored it for the summer before starting it. I live in Phoenix Arizona and summer time is not when I'm spinning wrenches in the garage.
I fired up the bike this week and it doesn't smoke!!! Halleluiah!!! Turns out the piston to cylinder clearance created by the machine shop that bored the cylinders the first time was the culprit all along. This has been a long and very frustrating process (three top end tear downs searching for the culprit) and at the end of it I can confidently say that they key to preventing this from happening is finding the right machine shop that has experience boring these smaller cylinders. As I stated in my previous posts I had Utah Crankshaft and Shortblock rebore the cylinders using NOS Honda pistons at .75 oversize and I can't thank them enough for getting it right. The turn time was very quick and the price was reasonable.
Thanks to everyone for your input and assistance. I wanted to circle back and post this solution to assist other restoration mechanics from going through the frustration of chasing down a problem that could have been prevented by using a machine shop that has experience with these smaller inline fours.
Now it's time to log some miles on this little CB350F and seat the rings!
Offline grcamna2
« Reply #97 on: February 03, 2023, 10:32:34 AM »
A great progress report on your CB350F top-end rebuild  8)
I have struggled with automotive type machine shops for years who have 'decided' that the correct specification for piston to cylinder clearance was "too tight"  ::)  I would like to have told them, 'I'm the customer,these are the specs:do your job' !  >:(  I have spent lots of $ repairing damaged jobs & getting cylinders rebored and getting new sets of oversize pistons and rings to say nothing of never-ending disappointing treatment;hey ! The losses to my trusting nature plus the price of that stuff adds-up.
I finally found a very good PowerSports Machinist(all he does is motorcycle parts w/ a few side jobs on other stuff once in a while)here in N. Cal. and been going to him for a few years;he's a one-man operation working out of his shop next to his house though so it does take time as he's very busy.
 Did you speak to someone over there at Utah Crankshaft that was able to make sure they followed all the specs and good communication? What part of Utah are they located in ?
« Last Edit: February 03, 2023, 10:39:32 AM by grcamna2 »
Offline SquierA
« Reply #98 on: February 03, 2023, 11:53:36 AM »
I found Utah Crankshaft on Ebay as they have a listing for pistons, wrist pins, rings and already bored cylinders for the CB350F for $899.99. The listing is still on ebay now.
I called them before I sent them my parts and explained my challenge and they measured the parts I sent them before reboring the cylinders. After they confirmed the out of spec measurements they rebored my cylinders and shipped my parts back in a timely manner and called me to let me know how the new bore measured. I was very pleased with their service.
They are located in Springville Utah and their phone number is 801-702-8142.
Offline grcamna2
« Reply #99 on: February 03, 2023, 12:13:38 PM »
Thanks for that.  8)
