Author Topic: Just throwing it out there for commentary  (Read 2025 times)
Offline itsahonda4
    • www.wfomodels.com
« on: November 05, 2016, 12:18:07 PM »
I am selling my unique 1969 bike, that has the warranty engine incorrectly stamped by the factory....
The bike was a sandcast and has all the correct sandcast bits - swingarm, air box, instruments, ducktail seat and so on, but the engine stamped CB750-1000767 is diecast. There is still a sandcast head on it, with the correct valve cover and so on, but to stress the point, the engine is diecast.
I have the correct 4 cable carbs, single cut fender in good shape, correct rear fender and a wrinkle tank.
Its all in large lumps, ready to undertake a full resto. Sidecovers and airbox are Yamiya parts new unpainted. Tank is not original paint and will need reapinting to match the new parts.
Soooooo, whats it worth?
Al
Re: Just throwing it out there for commentary
« Reply #1 on: November 05, 2016, 04:07:46 PM »
Diecast cases with sandcast clutch? That would make it obvious as to what it is IMO.
« Reply #2 on: November 05, 2016, 06:25:48 PM »
 Replacement case, A well known problem was chain failure on the early bikes that broke the cases. As far as value, I don't know. Someone here may be interested enough to PM.
 What's the frame number?
« Last Edit: November 05, 2016, 07:58:15 PM by Don R »
Offline itsahonda4
    • www.wfomodels.com
« Reply #3 on: November 05, 2016, 08:50:27 PM »
Frame number 10012120.typically the frame number would suggest it wasn't a sandcast but everything else on the bike suggests it originally was such a bike.
It appears that the replacement engine cases were ordered as a warranty unit, thats why they were stamped by the factory, but nonetheless, stamped wrong somehow, missing the 'E' out of the usual engine number sequence.
I have had an offer on the bike and will probably sell it locally for a bit less money but simplified delivery........
Al
« Reply #4 on: November 06, 2016, 04:01:27 AM »
 To be honest it still sounds pretty much like an early K0 die cast with the frame serial numbers. Sandies had a double cut front fender. Early Sandcast had the horn mount on the left side and carb tops had a #28 stamped on them. Hopefully some other folks can give you some more clues to look for. Ko's had wrinkle tanks, 4 cable carbs, single cut front fender etc. so that is not unique to a sandcast.
« Reply #5 on: November 06, 2016, 08:34:06 AM »
A lot of early diecast shared a lot of the same parts as sandcast.
When you say sandcast head and valvecover, what id different on those ? Heads that look the same were used on over 1/2 of the KO models.
 If the motor was in the 700 range there would be many differences, but hard for a lot of people to tell. Do you carbs have number tops, and the long choke lever ?  If not, they never were on an early bike. How many holes on the clutch cover?
Offline itsahonda4
    • www.wfomodels.com
« Reply #6 on: November 06, 2016, 11:41:19 AM »
Carbs have number tops and the long choke lever, im going out to check the clutch cover shortly.....
Head doesnt have the front bolt that was introduced later.....
Offline kmb69
« Reply #7 on: November 06, 2016, 02:09:18 PM »
Al
Looks like maybe an extra digit in your frame number.
Might be a Sandcast if the frame is actually CB750-1002120. Except for a few French Sandcasts, the US SC frame numbers only had 4 significant digits.
Pretty sure the factory NEVER stamped replacement cases. I replaced a bunch of them back in the day and they all came new in the box unstamped.
Sounds like the shop that replaced them or the PO fu-barred the case stamping. Pictures of the frame/engine numbers would confirm the Honda font or not.
I have CB750E-1007419 and it's all Sandcast stuff except for the cases. Also have a couple of 4 digit K0's that are all Sandcast stuff except for the cases.
Sounds like SC carbs for sure but not likely those are the original carbs if frame is really CB750-10012120.
Offline itsahonda4
    • www.wfomodels.com
« Reply #8 on: November 06, 2016, 03:38:20 PM »
Yes the frame is 12120, so we know if definitely isnt a SC......
10 holes in the clutch cover.
Either way its an interesting Frankenbike, but of no significant value other than as a conversation piece I guess.......
Thanks for the input.
Al
« Reply #9 on: November 06, 2016, 03:54:17 PM »
 K0 bikes can have significant value, lots more than later year bikes especially when they still have stock early parts.
Offline kmb69
« Reply #10 on: November 06, 2016, 06:15:20 PM »
I would be interested in buying those carbs if they are for sale. Please post pics if you would like to sell them.
Keith
Offline itsahonda4
    • www.wfomodels.com
« Reply #11 on: November 06, 2016, 06:31:44 PM »
Hi Keith, im not going to part out the bike, its much too complete to do that....
Im going to consider a local offer for the bike.
Thanks in any event
Al
