Author Topic: porting the two hose petcock?  (Read 1652 times)
« on: December 31, 2016, 06:21:59 PM »
 I was cleaning some petcocks and noticed the rather small size of the fuel passage inside the early petcock. It's nearly as small as one hose nipple. It seems like it may cause a flow restriction. Once upon a time I remember someone mentioning doing some work in there to help flow. Any ideas?
Offline firebane
Re: porting the two hose petcock?
« Reply #1 on: December 31, 2016, 07:07:49 PM »
I would like to know this as well but have wondered if you could convert dual to single output
« Reply #2 on: January 01, 2017, 03:51:37 PM »
 A rubber hose cap will plug one side easily enough. Hondaman says the single feed petcock bikes run a little more lean at WOT.
 Frankly I'm surprised a dual flows more judging by how it's built.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #3 on: January 03, 2017, 04:54:27 AM »
You can drill the fuel line spigot some....etc.
BentON Racing Website
BentON Racing Facebook
« Reply #4 on: January 03, 2017, 01:03:03 PM »
Try drilling them... Increase in area from 38-41. Is about 20.percent
 Numbers or unit measure dont matter, ratio stays the same.
« Reply #5 on: January 03, 2017, 02:53:02 PM »
 I was looking at the inside passage, it just seems so small. I'll play with one and post a pic.
