Author Topic: starter fluid  (Read 583 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
starter fluid
« on: February 15, 2017, 07:56:11 PM »
needing starter fluid to get the bike running.  once i get it running it'll run pretty well.  it's just getting it started.  does needing starter fluid point to a larger issue i'm missing?  it's 30 degrees here. i've barely gotten the bike to start running since it sat for 2+ years.  on a warmer day it's easier to start.
cb750 k6 - ugly
Offline DaveBarbier
Re: starter fluid
« Reply #1 on: February 16, 2017, 04:52:00 AM »
Are you using the choke to start it? Operating the choke properly?
Carbs are probably clogged a bit as to not let a richer mixture through to help a cold start up. I would do the complete 3k mile service and clean the carbs off the bike being sure to remove the jets and emulsion tubes.
Offline evinrude7
  • not a kung-fu
Re: starter fluid
« Reply #2 on: February 16, 2017, 04:59:32 AM »
thanks
cb750 k6 - ugly
Offline b52bombardier1
Re: starter fluid
« Reply #3 on: February 16, 2017, 06:10:01 AM »
There is a cold start procedure in the owners manual that seems to help.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline eigenvector
Re: starter fluid
« Reply #4 on: February 16, 2017, 07:51:51 PM »
Definitely not recommended to use starter fluid.
I'm guilty of relying on it, learned my lesson, now I stay away from it unless it's 30 below or something.
When it's really cold and the battery is just not cranking - I use a remote starter kit (basically a portable car battery) so as to avoid draining the bike's battery.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
