Author Topic: Can't find a torque number for alternator rotor bolt. Anybody?  (Read 3567 times)
Offline greenjeans
  • 1972 CB750K2
« on: February 17, 2017, 01:27:12 PM »
75 CB750K
Putting the starter clutch and alt rotor back on.  Can't find the torque value for that bolt.  Anybody know?   I don't see it in my manual.
Offline my name is nobody
  • I like Pontiacs and Hondas
Re: Can't find a torque number for alternator rotor bolt. Anybody?
« Reply #1 on: February 17, 2017, 05:22:15 PM »
Clymer lists it at 22-29 ft. lbs.
« Reply #2 on: February 17, 2017, 05:48:35 PM »
The factory manual shows two different values; 57.9- 65.2 ft/lbs, and 72.3- 86.7 ft/lbs.
Offline tlbranth
« Reply #3 on: February 17, 2017, 06:10:51 PM »
Tighten 'til it feels right.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #4 on: February 17, 2017, 06:14:09 PM »
Edit: this has to be wrong. Disregard.
Offline disco
« Reply #5 on: February 18, 2017, 04:01:16 AM »
I think Dino said in his Hackaweek series that it was 75 ft/lbs.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline kmb69
« Reply #6 on: February 18, 2017, 06:39:12 AM »
Scottly, Which version manual(s) and where was it? I scanned early and late versions and could not find it. Must not have been thorough enough.
OK thanks. In my early manual, version 70.4, it is in Group 3-6, page 45. Shows 72.3 ft/lbs.
« Last Edit: February 18, 2017, 08:54:43 AM by kmb69 »
Online PeWe
« Reply #7 on: February 18, 2017, 07:43:48 AM »
I used an electrical wheel impact wrench while wife was standing on the crank placed on a thick wooden plank. I hope it tightened enough. I did not tighten that long, only until it started to hammer and 2-3 sec more.
Bolt threads locked with blue Loctite as it was before and same wrench had to work for a while (about 20 sec) to loosen it from my old crank. A friend was standing on the crank.
Both crank and alternator are now lightened, before only alternator. This might have an affect on needed torque too?
EDIT: The old CB750 shop manual specify 72.3 ft lbs (Group 2 page 53)
« Last Edit: February 18, 2017, 08:05:28 AM by PeWe »
Offline greenjeans
  • 1972 CB750K2
« Reply #8 on: February 20, 2017, 11:47:01 AM »
Is the consensus here to use loc-tite on that bolt ?
Offline drumstyx
« Reply #9 on: February 20, 2017, 11:57:49 AM »
Does this work like the rotor on my KLR where the rotor itself is a press fit, and the bolt kind of just pushes it on there? On the KLR I think you're supposed to go to something like 40, then 80, which could explain the multiple torque values.
I just didn't bother removing it when I rebuilt my engine. No real reason to IMO unless you're getting the crank lightened/balanced.
Online PeWe
« Reply #10 on: February 20, 2017, 12:53:08 PM »
My local tuner locked that bolt to summer -84. I did not use the bike that much after that,  40.000km until I removed it again due to crank swap.
It sat really good with  thread locker which I noticed when loosen it one year ago.
 I used medium strenght Loctite, blue. Not the tough 272. Cleaned bolt and treads with acetone before.
Offline kmb69
« Reply #11 on: February 20, 2017, 01:06:56 PM »
No. Never have.
