Author Topic: Balancing Rear Wheel?  (Read 634 times)
Offline Sigop
« on: March 09, 2017, 04:49:55 AM »
Balance before replacing sprocket hub and sprocket, or with all parts reassembled?
Or doesn't it matter?
Thanks.  8)
CB750 K3  Original Owner and Operator
Offline 540nova
Re: Balancing Rear Wheel?
« Reply #1 on: March 09, 2017, 05:00:02 AM »
All parts assembled for best results
Offline Sigop
« Reply #2 on: March 10, 2017, 04:25:37 AM »
Thank you.
Offline rotortiller
« Reply #3 on: March 10, 2017, 05:47:07 PM »
Only balance the rotating parts, not everything. The brake plate should left off. Crush drive rubbers and sprocket hub can move. You really need to put the balancer cones on the two  inner wheel bearings. You  can use the axle on knife edges with the sprocket hub in place but you still should remove the brake hub assy.
