Author Topic: clogged fuel tank crossovers CB350, creative solutions asked for  (Read 8130 times)
Re: clogged fuel tank crossovers CB350, creative solutions asked for
« Reply #25 on: May 31, 2017, 09:07:36 AM »
I an thinking, the end of the speedo cable, did you sharpen it, make it more drill like, or perhaps like a spade drill ? So it can actually cut..
Get the part to the corner with a drill...
 I am thinking if you had a thick piece of  copper wire, sharpened.. About 1/2 the hole diameter...it may start bending while cutting, and follow around the corner. Turn slowly.
Offline strynboen
« Reply #26 on: May 31, 2017, 09:11:22 AM »
the tire is korrekt mounted for a rear tire...vhen used as front tire..it need to run vith the arow..oh somone vas there befor mee.. :-X
« Last Edit: May 31, 2017, 09:18:59 AM by strynboen »
i hate all this v-w.... vords
Offline grcamna2
« Reply #27 on: May 31, 2017, 09:28:05 AM »
I know that cable 'inner' is strong,possibly use a large dia. cable 'inner' from another application like an automobile clutch cable of the correct dia. to fit inside that bend and maybe solder the end of it first..
75' CB400F/'bunch o' parts'
Offline MoMo
  • Ride like you're invisible
« Reply #28 on: May 31, 2017, 12:39:16 PM »
The speedo cable had a rounded point to the end, in combination with the MEK solution it worked.  I was thinking of sharpening it but it worked as is, probably would have been quicker if sharpened.  Most likely attempting to sharpen a twisted cable would have frayed it.
  Plans for painting the Fuglyone to follow....Larry
