Author Topic: 1982 Honda custom 250cc shift  (Read 1124 times)
Offline CallBob
« on: May 27, 2017, 12:07:35 PM »
i am having trouble getting my sneaker to go under the shift .. is there a way to adjust this ?
Offline Gordon
  • 750K1, 550K2
Re: 1982 Honda custom 250cc shift
« Reply #1 on: May 27, 2017, 01:50:48 PM »
You should be able to remove the shift lever and reinstall it at a slightly higher angle to leave more room for your toe.
Offline tbpmusic
« Reply #2 on: May 27, 2017, 04:08:24 PM »
You might also be able to source a heel-toe shift pedal, they're pretty common.........
Bill Lane
