Author Topic: Honda Dream 50 (new member)  (Read 7100 times)
Offline v8ish
« on: June 13, 2017, 04:19:35 AM »
Hi guys, I've just got myself a Honda Dream 50 (a tribute to the late CR110's). technically I'm on the wrong forum given its a twin cam!!, but wondered if anyone can help?
The bikes CDI limits it to around 35mph, which is pretty painful. Takegawa used to make a replacement CDI, but stopped production.
I wondered if anyone had any experience of this bike and how I could go about removing the limiter in 4th and 5th gears?
It stops revving around 9krpm,
many thanks  8)
Offline jas67
Re: Honda Dream 50 (new member)
« Reply #1 on: June 14, 2017, 10:34:39 AM »
many thanks  8)
Cool!   I've always liked those.
So, does it NOT limit 1st through 3rd gears?
Disconnect the connection between the gear position sensor and the CDI, and hard wire it to think it is in a lower gear.
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
« Reply #2 on: June 14, 2017, 10:18:52 PM »
You are going to need a rev limiter or overrevving will damage the motor. 35 mph is way low...these were race bikes first. Did you buy a german model that was speed limited?
Is the bike's gearing stock?
David
Offline vfourfreak
  • Do you think that's wise
« Reply #3 on: June 15, 2017, 05:05:57 AM »
The Takegawa Hyper CDI you need is part number 07-02-17. It is apparently discontinued but still shows up as available on some stores
e.g. this one in Belgium http://www.daxshop.be/nl/a/daxshop_1_hoofdmenu_takegawa/takegawa-hyper-cdi-voor-honda-dream50/
CMSNL in the Netherlands will let you order it, whether they can get one is another matter. I would wager that some of the Japanese sites will turn up one for you. Here is a thread started by a French guy doing just what you want to do : http://www.forum-auto.com/moto/essais-achats-conseils/sujet379048.htm (in French of course but let me know if you need help translating)
I had the Dream 50R version which had a HRC CDI kit without any limiter, as my neighbours can attest to. The HRC kit may be still available, but no doubt for a scandalous price - part N° 06340-NKR-000
Kev
Offline v8ish
« Reply #4 on: June 16, 2017, 02:02:03 AM »
Guys - Thanks so much for the replies. All useful.
The bike is stock - I have done another test today and its actually limited to 60kph so that's 37kph. It was direct from Japan, I think theres a legal requirement for a "moped" to be limited over there.
I've done some work on Jas's idea and found a guy that's done this - look about 3/4's down the page (by the full fairing picture).  http://motor.geocities.jp/love27/dream50.html
It essentially means putting a couple of wires into the CDI connector. I strapped the bike up, stuck it in 5th and hey presto, the limiter is gone. I haven't tried on the road yet.
This method does make me slightly nervous - I have tested if its by passed the rev limiter completely. But it does seem to work.
Vfourfreak, thanks for info, I checked the sites and unfortunately both seem to say out of stock.
Seems I've found a solution but not quite ideal - but seems to work!
Offline vfourfreak
« Reply #5 on: June 16, 2017, 02:44:23 AM »
My RVF400 is a Japanese import and was speed restricted also. The restriction on these models is implemented in the speedometer, and I used the tip here :
http://www.veaminicori.talktalk.net/Articles/derestriction.pdf
to succesfully derestrict it. Perhaps there is a similar implementation in the Dream 50 ??
Kev
Offline spurlock
Re: Honda Dream 50 speed limiter fix!
« Reply #6 on: September 19, 2018, 08:22:34 AM »
I realize this is a long dormant thread, but just in case the OP still has a problem with the speed limiter I can offer the simple solution which I learned from a Dream 50 Facebook group. Just attach jumper wires to the CDI plug to connect the red/white, white/yellow, and green/red leads. Plug the connector back in and viola, no more rpm limitation in 4th and 5th gears.
I recently acquired a Dream 50 (CB50V) and it came with the Takegawa Hyper CDI which also eliminates the speed limiter. But when I checked with a timing light I was surprised that the Hyper CDI maintains timing at the stock full advance setting at all RPMs. In other words the timing does not retard at idle. That made the idle rough and the bike tended to kick back when starting. I was afraid of damage to the starter pawl or gears so I removed the Hyper CDI and went the jumper wire route. No difference in the full advance timing and the bike idles better. Here's my little gem-
-Bill
1975 Honda CB125S, 1989 Honda NX250, 1989 Honda GB500, 1989 Honda CB-1 400F, 1997 Honda Dream 50
« Reply #7 on: September 19, 2018, 07:59:39 PM »
Hey Bill, how fast does the Dream 50 go without the rev limiter? Cool bike!! The CB-1 is also cool!!
Offline spurlock
« Reply #8 on: September 20, 2018, 07:18:16 AM »
Right now she runs out of breath around 60 but I still have a bit of carb/intake system work to do. The thing is though, being on such a small bike and so low to the ground it really feels way faster!
-Bill
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: September 24, 2018, 09:00:36 AM »
Is the photo with the lake behind the bike recent? Looks like Berryessa is almost full!
The boaters love that.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline spurlock
« Reply #10 on: September 24, 2018, 11:42:38 AM »
Last winter was dry so it's now ~16' down from full. But after the previous very wet winter it topped out several feet above the glory hole. It was mesmerizing to watch and really drew crowds.
-Bill
« Reply #11 on: September 28, 2018, 11:17:03 PM »
What is a glory hole and what does it do? Does it serve to maintain water level in a lake that is man-made without having a dam?
Thanks! David
PS nice photos
Offline spurlock
« Reply #12 on: September 29, 2018, 06:30:57 AM »
Thanks! David
PS nice photos
It's an overflow, located right next to the dam. Limits maximum lake level.
-Bill
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #13 on: September 29, 2018, 09:55:32 AM »
It’s the same thing as a spillway on other dams. Lake Berryessa also has a small generator to make a little power from the mandatory flows out of the dam that keep Putah Creek flowing. The creek has a great catch and release trout fishery as well as some salmon sometimes. The lake is for irrigation, water users and recreation.
1973 CB 750 K3
Offline Bottletop
« Reply #14 on: February 19, 2025, 03:52:45 PM »
Just got an AC15, been after one for a while, its been stood for three years at least. Low km and in great condition, just dusty and elbow grease needed. Want to service it and start getting it back on the road. Can anyone recommend what grade of oil 10/30w or 10/40w? Any brand? Original tyres are rock hard any pointers to get correct looking replacements? Thank you.
Offline spurlock
« Reply #15 on: February 19, 2025, 04:25:51 PM »
Any decent multi grade oil is fine. Not sure what tires are available in the UK, but here in the US the OEM Bridgestone BT39SS tires are no longer available and the only look-alikes I can find here are these:
https://www.ebay.com/p/171139331
and the more modern looking
https://www.chapmoto.com/continental-conti-street-front-tire-339-02403960000.html
-Bill
Offline carnivorous chicken
« Reply #16 on: February 20, 2025, 08:33:33 AM »
-Bill
It's also a legendary skateboarding spot. The pipe below is probably around 26'. I skated it in 1987, but people still skate these days (well, not now because it's wet...).
Offline Bottletop
« Reply #17 on: February 20, 2025, 10:13:56 AM »
Cheers spurlock/Bill for the pointers, greatly appreciated. Need to get a new lid my last one was a FM Force One, probably a collectors item now. Its starting to add up, tyres, helmet, service, mot.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #18 on: February 24, 2025, 07:04:35 AM »
Cool to see Berryessa flowing down the spillway.
1973 CB 750 K3
