Author Topic: Help! What CB550 parts will work on my 71 CB500?  (Read 1542 times)
Offline SupremeOrigin
« on: September 27, 2017, 10:02:58 PM »
So I have my original 71 CB500 rims, the hubs  (both front and rear) are junk due to being stripped. Could I use CB550 ones and what years work?
Also would the complete forks from a CB550 work with my Frame and bolt up to the stock CB500 brake?
I am having a hard time finding CB500 parts so Im hoping someone can help.
Offline Bankerdanny
  • Endeavor to persevere
Re: Help! What CB550 parts will work on my 71 CB500?
« Reply #1 on: September 28, 2017, 04:52:57 AM »
Pre-77.
« Reply #2 on: September 28, 2017, 10:09:53 AM »
I got a 72 Cb 500 parts bike for my 74 cb 550.  The frames and wheels are the closest cross match. They changed a bunch of things for the f model in 1975. Even the k model was disappointing in a chassis parts cross.  For one the kick stand moved positions.  I know the rear wheel wouldn't direct swap from the f model to the 74.
If you are shopping for a parts bike, probably look for pre 77, then k models and then 74 k .  Of course the earlier cb 500 you can find the better for chassis parts.
But if you are looking to swap in a 550 engine the 74 is probably the best for the most parts crossover.
Offline jonda500
« Reply #3 on: October 03, 2017, 04:01:30 PM »
Any pre '77 500/550 rear wheels/hubs will fit - 77/78 rear wheels will fit but you would need the 77/78 hub, brake backing plate and right side spacer
Any 71-78 500/550 Four forks will bolt straight in and look identical on the outside
John
A starter clutch thread:
