Author Topic: Jetting  (Read 4774 times)
Offline Johnny340
Jetting
« on: March 13, 2018, 04:58:17 PM »
I have searched the multiple threads about jetting and don't want to get into a debate about airboxes vs pods.  I have bikes with airboxes and this one doesn't.
I haven't read about a starting point for my setup, which is:
836 with Wiseco pistons.
K&N pod filters.
Carpy 4 into 1 open exhaust.
I currently have this jetting (stock is in brackets):
Main jets: 125 (105)
Pilot Jets: 45 (40)
Needle Clip position: Bottom (middle)
Air Screw: 1/4T (1 & 1/2T)
There is a slight hang at 2300RPM before settling into idle below 1000RPM that I'd like to get rid of.
Any constructive suggestions (besides putting the airbox back on) are welcomed.  I know I'm not the first one to run an SOHC CB750 with this setup.  Thank you!
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Paintedseat
Re: Jetting
« Reply #1 on: March 13, 2018, 08:04:17 PM »
Are you sure the pilot jets were 40 from the factory? I would turn air screws out 1.5. Are you saying you need to blip the throttle when you come to a stop?
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: Jetting
« Reply #2 on: March 13, 2018, 08:04:29 PM »
Usually, when a bike hangs at a higher idle before dropping to the idle setting, it is because of a lean condition. Now this is the lower rpm range, so it could be due to the idle circuitry being partially blocked with crud, or the needle jet itself having emulsion holes blocked. If that isn't the case, I remember Hondaman's FAQ's stating that you can enlarge the upper holes in the pilot jets, and perhaps also in the needle jet. The pilot jet has 8 holes on them and you enlarge the 4 upper holes for a better emulsion, and it is supposed to get rid of that flat spot, if i remember correctly. You will have to look at his 'Thoughts' in the FAQ section to read what I am referring to.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Johnny340
Re: Jetting
« Reply #3 on: March 13, 2018, 08:10:39 PM »
I believe they were 40 stock. Yes, I had to blip the throttle mostly because the idle was set too low (to confirm that wasn't responsible for the idle hanging up). It ran worse with the air screws at 1.5T..
Sent from my SM-G930W8 using Tapatalk
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Johnny340
Re: Jetting
« Reply #4 on: March 13, 2018, 08:14:25 PM »
Charlie
Thanks Charlie. I agree on too lean down low. I'll pull the carbs again and confirm pilots and emulsion tubes clear. The enlarging idea sounds clever. I don't have his book though..  There was some crud from the tank, but I thought I cleaned it all out. Off come the carbs again.. I getting good at that!
Thank you for the suggestions and if anyone can detail that enlarging procedure I'd really appreciate it!
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Yamahawk
Re: Jetting
« Reply #5 on: March 13, 2018, 08:15:33 PM »
It's in the FAQ section here on the forum :)
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Johnny340
Re: Jetting
« Reply #6 on: March 13, 2018, 08:15:59 PM »
I will search the 'Thoughts of A Honda man' but I don't recall reading that part before.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Jetting
« Reply #7 on: March 13, 2018, 08:22:37 PM »
exactly what carbs do you have? 086a?  I have a mostly untested hypothesis that 086a have the best needle profile for pods/short/open pipes.  So if you have 086a and the needle is already on the bottom clip position and it's still too lean?...this is why you run an airbox
Offline Johnny340
Re: Jetting
« Reply #8 on: March 13, 2018, 08:28:34 PM »
I have Keihin 064A carbs.
Sent from my iPad using Tapatalk
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Yamahawk
Re: Jetting
« Reply #9 on: March 13, 2018, 08:29:39 PM »
http://forums.sohc4.net/index.php/topic,7401.0.html
Reply #13 for the emulsion tube mods...
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Re: Jetting
« Reply #10 on: March 13, 2018, 08:40:04 PM »
hold up on my claims here...I might have my numbers mixed up.  Gotta go look some stuff up.
Offline Johnny340
Re: Jetting
« Reply #11 on: March 13, 2018, 08:41:09 PM »
Charlie
Thanks Charlie, got now it!
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Jetting
« Reply #12 on: March 13, 2018, 09:00:01 PM »
ok, I am gonna stick with the 086a's being the best needle...according to this chart
www.hondachopper.com/garage/carb_specs/carb_specs.html    I think you mis read 069a as 064a which supposedly have the same needle as 086a.  However, no absolute confirmation on the total accuracy of this chart.  Honda was very slippery on what parts they used on what bikes plus things have been swapped around so much over the years.  But, please note, only three different needles were available throughout the model run.  Also note there is NO information on needle jet size and emulsion tubes to be found anywhere.  Compare that to Mikuni VM's which offer dozens of needles and needle jets and guys still have limited success tuning those for modified intake/exhaust.  So this is why so little really useful info can be found.
I have had luck adding a small straight through glasspack...seems to trick your pipe into thinking it is longer.
Offline Johnny340
Re: Jetting
« Reply #13 on: March 13, 2018, 09:12:31 PM »
You're right, I misread that number. Looks like JN (jet needle?) is different.. 2 vs 4. Thanks for the link.
I'll try that emulsion tube hole enlargement next.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Jetting
« Reply #14 on: March 14, 2018, 03:55:12 AM »
Also, make sure your timing advancer is working properly and do a clear tube test for float bowl fuel levels.  Otherwise you will just be chasing your tail.
Offline Johnny340
Re: Jetting
« Reply #15 on: March 14, 2018, 10:32:17 AM »
OK I did not misread that number.  064A for sure which, according to this chart is correct for my bike ('75 F model):
http://www.globalarray.net/user/mike_in_phoenix/motorcycle/text/specs_revised.html
I'm not sure how the needle compares to the one you prefer Sean.
The timing advancer is perfect.  I will do the clear tube method to test the actual float levels.  I looked that up but of course the photobucket images are not available  ::)  These carbs have the separate drain screw so I suppose I'll be looking for some brass fitting that threads in.. Edit:  Just found Flybox's heated tube method.  Cool.   I'm going away for a few days and will tackle this as well as the Pilot Jet emulsifier tubes when I get back.  Thanks again for the constructive comments!  :)
« Last Edit: March 14, 2018, 10:42:43 AM by Johnny340 »
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Jetting
« Reply #16 on: March 14, 2018, 01:16:57 PM »
that is interesting...the guy that made that chart certainly knows his #$%* although he himself notes that it contains/ed several errors.  Pretty sure you are right about 064a being correct as I now remember that 069a was for the 550's.  I have owned 2 '75 750f's and they both had 086a but their is probably more evidence of them being swapped than there is for them being original...but what I am getting at is they both had pods when I got them and ran well without even a good carb cleaning.  I changed both to Henry Abe breadboxes, made a couple mainjet adjustments and had them both running and performing as good as with a stock airbox.  Interestingly, the 2 bikes wanted very different main jets with very similar induction/exhaust.
Offline setdog
Re: Jetting
« Reply #17 on: March 14, 2018, 07:34:13 PM »
those carbs looks nice.  generally your problem sounds pretty mild, so id be looking for a very slight adjustment somewhere.
are you using keihin jets or aftermarket? i think keihin is better way to go.  id first just go after the jets with some wire and clean the hell out them
i may get some cringes for what im about to say, but i sometimes think too much time is spent getting the jetting size and combination right, when its just
cleaning jet holes and mixture screw settings that need attention.  small adjustments to mixture screws can yield good results.
ill leave out the episode where i failed to put back my vacuum screws and nearly went crazy.
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline Johnny340
Re: Jetting
« Reply #18 on: March 17, 2018, 01:59:01 PM »
So I enlarged the top four emulsifier holes in the 45 pilot jets and it still hangs up before idling down. The video is from when it runs best. When the air screws are open 1 turn it hangs at 2500RPM for way longer before idling down. But with the air screws only open a quarter turn it doesn't idle that well once it finally does settle into the idle..
Everything is clean inside these carbs. http://cloud.tapatalk.com/s/5aad8062b2eeb/20180317_131920.mp4
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Jetting
« Reply #19 on: March 17, 2018, 02:22:46 PM »
that's a weird one...does look like you got the idle speed set way too low.  Try about 1100 rpm, not 600
Offline Johnny340
Re: Jetting
« Reply #20 on: March 17, 2018, 02:23:54 PM »
If I set it that low then it hangs up at 2500 even longer... Sometimes indefinitely.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Jetting
« Reply #21 on: March 17, 2018, 02:34:38 PM »
have you tried to ride it? how does it perform?
Re: Jetting
« Reply #22 on: March 17, 2018, 02:39:12 PM »
ok, not understanding...from your video it looks like your idle speed is set at 600 rpm, it should idle at about 1100-1300
Offline Johnny340
Re: Jetting
« Reply #23 on: March 17, 2018, 02:52:50 PM »
If I set the idle speed to 1100 or so, then blip the throttle it revs up high but hangs even longer at 2400-3000RPM.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Jetting
« Reply #24 on: March 17, 2018, 03:00:33 PM »
I would say you need bigger idle jet, but is anything bigger available?
Any chance you got confused on the clip position and put it all the way at the top(leaner) instead of all the way at the bottom(richer)?
Something is not right here
Have you had a look at the plugs?
