Author Topic: Fuel Connections to CB550 069A Carbs?  (Read 515 times)
Offline cb_n00b
« on: March 17, 2018, 11:52:36 AM »
I recently picked up a set of 069A carbs to replace my PD46A carbs on my '77 CB550K...On the 069A carbs, there are two fuel hoses coming out of the engine side of the carb bank, one hose into carbs 1&2, and another into carbs 3&4.
On my PD carbs, there is only 1 fuel connection from the petcock to the carbs, so do I need something like a Y-connector to run from the one petcock outlet into the 2 fuel hoses in the carbs? OR should I just get a new 2-outlet petcock?
I'm assuming the two hoses are for fuel from the main fuel supply setting and from the reserve setting on the 2-prong petcock, but does that even matter if I only have one outlet on my petcock? If not, do I only need to connect to one of the fuel lines?
Thanks and sorry in advance if this is a really dumb question!
1977 CB550K
- MotoGP Werks Exhaust / Stock Airbox
- Dyna S Ignition & Coils
- Motogadget M-Unit Blue
- 069A CB550F Carbs
- Beringer front brake kit
Re: Fuel Connections to CB550 069A Carbs?
« Reply #1 on: March 17, 2018, 11:54:06 AM »
Just use a Y or a T fitting to split the fuel line.
Offline cb_n00b
« Reply #2 on: March 17, 2018, 11:54:50 AM »
Perfect. Thanks TT!
1977 CB550K
- 069A CB550F Carbs
