Author Topic: 650 top end on 550 is it possible ?  (Read 2548 times)
Offline OZZYSBIKES
« on: March 31, 2018, 09:35:47 AM »
HI
I am new to the forum, just bought my first four cylinder Honda (I have wanted one since I was 12 years old, I am now 58 !), I have bought my favourite one, a 1978 550K, not everyones first choice but I love them,
anyway to my question, can a 650 top end be fitted on 550 bottom end ? I saw an article from this forum on google but it contained lots of photos that were on photobucket that I cannot open so I got a little lost trying to follow the article, I think the answer to the question is yes it can be done but it involves some modification, I have already acquired a 650 top end and I was also thinking of getting a crankshaft,
Any advice or pointers will be much appreciated, the obvious reason for doing it is to give the bike a bit more power and torque for the longer distance runs that the bike is for (I have a 74 and a 89 RD350 for the quick blast)
I am in England, thanks Jeff
Offline Bankerdanny
  • Endeavor to persevere
Re: 650 top end on 550 is it possible ?
« Reply #1 on: March 31, 2018, 04:57:59 PM »
The 650 engine bolts right into the 550 frame,  what you are proposing is a lot of work without much payoff. Just buy a 605 kit and use the 650 cam or find a complete 650 engine.
Offline DaveBarbier
« Reply #2 on: March 31, 2018, 06:24:53 PM »
You may have read this post by Paulages: http://forums.sohc4.net/index.php?topic=40414.0
Other than keeping the look of the 550 bottom end or to maintain a kick starter, I don’t see any reason to do a mod like this. The 650 bottom end is an improvement over the 550.
I think you’d need the 650 crank, not sure the stroke is the same as the 550.
« Reply #3 on: March 31, 2018, 06:42:45 PM »
+1 ... If your 550 needs more balls, drop the entire 650 motor in it! Or buy a 750.
Click here for the fotobukit fix.....
http://forums.sohc4.net/index.php/topic,168102.0.html
Offline nicks2319
  • Youngstown, OH
« Reply #4 on: April 01, 2018, 03:16:48 PM »
650 cam alone would probably be worth it. Or even an aftermarket one.
Offline OZZYSBIKES
« Reply #5 on: April 02, 2018, 12:38:08 AM »
HI All,
Thanks for the advice, as mentioned, I want to retain the look of the 550 bottom end and the 750 is a bigger heavier bike so it doesn't fit the bill, it looks like it might be worth just putting a 650 camshaft (which I believe also needs some alteration) and a big bore kit, does anyone know if the 650 crank is a straight swap ? I understand the ignition pickup is 180 degrees away but easy enough to swap over the ignition coil trigger wires ?
I might be in luck with buying a complete 650 engine, I am favouring keeping the crankcases etc of the 550, I am not bothered about the work as I enjoy tinkering as much as riding my bikes,
Unfortunately the link to fix the photobucket issue (for Chrome) wouldn't work for me (looks like the link has been disabled)
A quick thought, I might do a twin disc conversion, does anyone know an original looking master cylinder that is suitable for the twin disc setup
Thanks
Offline OZZYSBIKES
« Reply #6 on: April 02, 2018, 01:57:38 AM »
I have found a correct master cylinder, the one from the 76 Gold wing fits the bill, a repro one from David silver is available and cheap
Offline DaveBarbier
« Reply #7 on: April 02, 2018, 02:22:21 AM »
The 650 cam cover is drastically different than the 550, but I see what you’re saying. Trying to keep the look of the motor as much as you can while upgrading the internals.
The 650 cam swap doesn’t normally need modification. I have read some members need to dremel down where the lobes may contact the head. Other than that, it’s a direct swap...will also need the tach gear and tachometer.
Offline OZZYSBIKES
« Reply #8 on: April 02, 2018, 02:36:58 AM »
The tachometer ? I have heard about the drive may need swapping but not heard of having to put a new tacho head unit on ??
Offline flatlander
« Reply #9 on: April 02, 2018, 06:08:26 AM »
i see what you want, preserving the original look of the 550 but giving it more power. however, swapping in a 650 topend will make it look very different there, apart from the heavy work needed which i think is not worth it. you have mainly three options:
550 engine + bigbore + 650 cam
cheapest option, gives you more grunt but less power than the others.
easy: get a low compression bigbore kit from.cruzinimage on ebay, get a second hand 650 cam... engine will look like original 550 only the tach gauge will need to be swapped to a 650 or 750 for accurate reading.
650 full engine swap-in
gives you the most power increase at relatively low cost (if you can keep.your fingers off making additional performance mods). but of course it won't look like a 550 any more.
there are a few threads on here covering this, including dave who posted here.
550 engine + heavier performance mods
most expensive option giving a lot more power over stock but less than the 650 engine. keeps the complete original 550 look. check the link in my signature for details.
Offline DaveBarbier
« Reply #10 on: April 02, 2018, 06:50:23 AM »
Forgot about the 650 motor swap with a 674 kit, ported head, hotter cam and race carbs :)). Worst of both worlds, expensive and looks nothing like a 550, haha.
Offline flatlander
« Reply #11 on: April 02, 2018, 07:04:28 AM »
ha ha worst of both worlds indeed  ;D
Offline crazypj
  • I'm brill, me
« Reply #12 on: April 02, 2018, 04:30:19 PM »
I got one, with rods and cam sprocket
Not sure if I'll ever get around to fitting it in my 550
Offline scunny
  • don't call me expert
« Reply #13 on: April 02, 2018, 10:31:40 PM »
650 stroke 55.8mm
550 stroke 50.6mm
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline crazypj
  • I'm brill, me
« Reply #14 on: April 03, 2018, 02:04:46 PM »
I think I'll keep the 650 crank I have, sounds like a CB750 piston, longer stroke motor will eventually get built  ;D
(unless I find a 650 block, already have some Suzuki liners for 70mm bore, if that's even possible?)
Offline Gordo
« Reply #15 on: April 04, 2018, 12:31:42 AM »
« Reply #16 on: April 04, 2018, 02:00:26 AM »
the 10 or 12 horsepower increase from 550 to 650 is because its 100cc bigger,about the power of any old era Honda 100cc.
Offline flatlander
« Reply #17 on: April 04, 2018, 03:12:58 AM »
does anyone know actual, dyno measured rear wheel power of an original 650?
i think honda advertised it with 63hp at the crank but considering how "optimistic" their numbers were, they may only have around 50hp at the rear wheel?
Offline DaveBarbier
« Reply #18 on: April 04, 2018, 03:51:08 AM »
Don’t know the actual number, but I have heard around 49-53 quoted at the wheel.
Offline flatlander
« Reply #19 on: April 04, 2018, 04:51:43 AM »
that sounds realistic. then the mods that i did to the 550 actually get you in the same area or potentially slightly better than a stock 650, only at higher cost than the engine swap.
Offline crazypj
  • I'm brill, me
« Reply #20 on: April 04, 2018, 11:59:47 AM »
Hey dude this is a very good how to http://manuals.sohc4.net/cb550/technical_reference/TR550650_BIG_BORE.pdf
Thanks Gordo, the PDF is much easier to save
