Author Topic: 750 K7 fork stiff  (Read 3514 times)
Offline Erny
750 K7 fork stiff
« on: April 15, 2018, 01:37:19 PM »
Today did another 160miles and definitely confirmed fork is too stiff, it does not "eat" bumps, moves just little or slow, as result i felt all bumps in bars...
Of course when standing, if I press brake and I push bars it moves, this looks normal.
Any idea what except f checking right amount of fork oil i can check? PO changed seals and put new oil.
« Last Edit: April 15, 2018, 01:54:25 PM by Erny »
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Bankerdanny
  • Endeavor to persevere
Re: 750 K7 fork stiff
« Reply #1 on: April 15, 2018, 03:21:56 PM »
What weight oil did you use and how much do you weigh?
At 240-250lbs (108-113kg) I use 15wt oil.
Offline Erny
« Reply #2 on: April 16, 2018, 02:38:02 PM »
PO told me he pit there Motul 10w. My weight is 80kg
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #3 on: April 16, 2018, 04:01:42 PM »
Erny,
  Check the level of the oil in your forks, to see if they are too full. Sometimes it will stiffen up the forks a lot if the oil level is over the recommended height in your fork tubes. Mosul 10w should be fine for your weight.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Erny
« Reply #4 on: April 17, 2018, 05:28:05 AM »
Erny,
Charlie
That's exactly what I plan to do as the only thing I can
« Reply #5 on: April 17, 2018, 05:39:10 AM »
This is a long shot, people sometimes put a spacer under the top nut to compress the springs to make up for fatigue or stiffen the forks. This of course limits the travel and make them bottom out easier.
One other thing. is this a perception on you part about feeling the bumps? I am not sure of your riding experience or the bikes you have ridden. 80kg is about 160 lbs, I admire you.  ;D
Offline pjlogue
« Reply #6 on: April 17, 2018, 05:49:40 AM »
When I restored my 750 I put in 10W-30 and found my forks were too stiff for a comfortable ride.  I'm 210lb.  I switched to ATF and it made a big difference in ride quality.  My riding style is laid back and not pushing the bike.  If your oil levels in the forks are correct and you have normal (not heavy weight springs) and no spacers give the ATF a try.
You should also check for wear of the forks, binding/stiction of the seals.  Some seals can be pretty tight against the down tubes and cause a harsh ride.
-P.
Offline Erny
« Reply #7 on: April 17, 2018, 05:59:09 AM »
-P.
What is ATF? (sorry for stupid question)
Yes seals is another story, PO have put new might be issue too... Maybe I shoud preventively replace them by OEM ones of they are still obtainable.
Offline Yamahawk
« Reply #8 on: April 17, 2018, 06:16:57 AM »
Yep, this does happen. There is also people who cut the springs to stiffen them and then fabricate a spacer to add back then length they cut. It's a common mod on the Concours forum, but it limits travel somewhat as the coils can bind if a heavy pothole/bump is encountered. The Best Way to take care of forks, is to properly rebuild them with new, straight wound springs, from RaceTech, Sonic, or one of the other popular brands, and use a proper weight fork oil for your weight. Progressive doesn't make a bad spring, just use RaceTech's spring rate calculator to get the proper load rate for the new springs. If they sell you the factory spring rate, they were already too light when new, and then go downhill from there.
Here is Sonic's spring rate calculator...
http://sonicsprings.com/catalog/calculate_spring_rate.php
and here is RaceTech's... make sure you pick street bike
http://racetech.com/VehicleSearch
   ...And ATF is automatic transmission fluid
Charlie
« Last Edit: April 17, 2018, 06:19:09 AM by Yamahawk »
Edmund Burke
Romans 8:28
Job 13:15
Offline Erny
« Reply #9 on: April 17, 2018, 07:16:11 AM »
Thanks,  Charlie
I expect that springs are stock original, bike has only less 9000miles from new. But I did not opened then yet. Will do and let you know.
Concerning experience, I have experience with Honda CBF1000F (2010,model SC64, nothing special, just normal tourist bike with low cost forks) having very similar weight.
Simply riding CB750K I have feeling that forks does not move unless there is bigger bump or when braking with front brake. When looking at forks during ride I do not really see them moving, but I feel all bumps in my bars.
On the same road that I know for 20 years previous bike fork was working normally,it was simply moving significantly during ride.
And to add I also have BMW R1200GS LC 2016 that is of course completely different riding and feeling
« Last Edit: April 17, 2018, 07:18:40 AM by Erny »
Offline Yamahawk
« Reply #10 on: April 17, 2018, 07:26:29 AM »
Erny, the forks could be suffering from Stiction... try this. Loosen the front fork caps, and then pump the forks with the brake on. That will center the wheel in the forks, if it is out. Then tighten the fork caps.  Then, your triple trees can be done, loosen the upper right pinch bolt and lower left, pump the forks again, (re-tighten the bolts) then do the lower right and upper left to take out any misalignment in the trees. Remember to tighten the first two bolts before loosening then other two, or your forks will slip up into your trees... ;) There may be a method to do this in the SOHC manual, also.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Bankerdanny
« Reply #11 on: April 17, 2018, 08:18:04 AM »
-P.
ATF = Automatic Transmission Fluid. The owner's manual actually calls for ATF rather than fork oil on many of these bikes. I think it was because there wasn't fork oil available at the time and ATF resists foaming. If I recall correctly standard ATF is about the same viscosity as 10wt oil.
Offline RJ CB450
« Reply #12 on: April 17, 2018, 08:28:13 AM »
I havr progressive springs in one bike, nice spring.   That said, talk to recetech if you like to put the miles on.  I am doing a full racetech on one bike, and customer service alone has me as a loyal customer to them now.  Get them your weight and riding preference, they will hook you up.  Then there are the gold valves through them too if you got the forks off :-)
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
Offline Yamahawk
« Reply #13 on: April 17, 2018, 08:39:51 AM »
Using the Sonic spring rate calculator for 165lb. and 550lb. bike, for standard/sport touring  bike and normal riding, with a tank bag option, spring rate is .95Kg.
This is compared to the stock spring rate of .65 or even lighter... given the 40 years sitting on those springs, even with only 9k miles on them they will have spring sag, and you can see they are horribly under sprung, like every street bike out there. I am sure you stiffness isn't due to too stiff springs, but of fork oil viscosity and height, and fork seal stiction. Once you get those forks sorted, with proper damping and spring rate, you will find it rides like a modern bike... and if you stick emulators in there, it will be riding very well indeed.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #14 on: April 17, 2018, 11:31:03 AM »
My fork CB750K6 work extra good this season since I replaced the plastic piston rings inside. I have never replaced them before.
Item no 9
https://www.cmsnl.com/honda-cb750k7-four-usa_model14395/partslist/F07.html#results
Those pistons did just fall free inside the fork tubes before. Now they have do be pressed down.
I replaced the rebound springs too when at it. Item no 5 .I did not feel much difference when squeezing the springs by hand, old vs new.
I have progressive springs with no spacers.  Fork oil SAE 10 160mm from top fully collapsed without springs.
It work much better for the small bumps, before too soft.
« Reply #15 on: April 17, 2018, 04:24:27 PM »
PO told me he pit...
Dont ever believe PO....drain the oil
Offline tlbranth
« Reply #16 on: April 17, 2018, 05:47:27 PM »
Read this blog on Randall Washington's GL1000 site. It's a technique for removing 'sticktion' from your forks. I use this series of steps on the GL1000 and the CB750. It may solve your problem.
http://www.randakksblog.com/removing-stiction-from-gl1000-front-forks/
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Erny
« Reply #17 on: April 17, 2018, 10:12:08 PM »
Read this blog on Randall Washington's GL1000 site. It's...
Thanks!
Very interesting procedure, indeed.
To apply it on 750K7,do you know by chance what shall be level of air over oil in fully compressed fork? I assume GL forks are different from CB750K ones.
Offline tlbranth
« Reply #18 on: April 18, 2018, 08:03:00 AM »
On the CB I just put in the recommended volume of ATF. I don't measure depth so don't know the answer. Sorry.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Desert-SOHC
  • It's old
« Reply #19 on: April 18, 2018, 12:11:26 PM »
When I rebuilt the forks on my K8 I used ATF and they were to stiff, I ended up with 10wt fork oil to get it to ride decently.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
