Author Topic: '70 CB 750 Fuel Line Routing  (Read 1941 times)
Offline major domo
« on: April 26, 2018, 02:24:50 PM »
How is the fuel line routed for carb #'s 3 & 4 on a '70 CB750? Does it pass under the carb mounting bracket, them up to the spigot between the carbs? Also, is that fuel spigot supposed to point up or down? Might as well  ask about carbs 1 & 2 as well. Thanks in advance!
Ken
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: '70 CB 750 Fuel Line Routing
« Reply #1 on: April 26, 2018, 02:44:11 PM »
i'm not sure if anything is terribly different between any of the sohc bikes as far as general routing of fuel lines.  perhaps i'm wrong.  i've always been told take the most direct route and always head down hill from tank to carbs.  both of my spigots are down hill toward carbs.
cb750 k6 - ugly
Offline Johnie
« Reply #2 on: April 26, 2018, 02:52:20 PM »
The 1 & 2 fuel line on my KO's run over the top of the air box rubber then angle down to the petcock. Carb 3 & 4 it runs behind the stay plate and into the petcock. Both fuel T's are angled up between the carbs. Angle them the best way to not have a crimp.
« Last Edit: April 26, 2018, 02:56:02 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: April 26, 2018, 08:03:08 PM »
I had a little of the same trouble. Mine are like Johnnie's. My problem was the Yamiya grey fuel line. It was a little prone to kinking especially if it was too long. I got some more original looking black line that was a little thinner wall thickness. Problem went away.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline major domo
« Reply #4 on: April 27, 2018, 08:17:12 AM »
Thanks for the replies!
« Reply #5 on: April 28, 2018, 11:30:26 PM »
Yep, been here, done that, too...the K0 may or may not have the hole in the carb mount plate for the fuel hose that goes to the far side. This was added at the K1, which had 2 holes for the hoses to make sure the hose could not get kinked when they switched from the 5.0mm hose of the K0 setup to the 5.5mm hose of the later ones. Today, Honda is only offering an extra-thick (because it is ethanol-resistant) 5.5mm hose, although you can still try to order the 5.0mm part. Once in a while I can get some, but it goes quick! Look in the CB500-4 for the part number, if the fiche hasn't yet been "unitized".
