Author Topic: CB350F with short CB400 bars  (Read 634 times)
Offline poofdog
« on: May 14, 2018, 04:45:34 PM »
I just switched out some custom cruiser bars on my cb350f to the short repro cb400 bars.   Perfect feel for what I want.  The only problem I have is there isn't enough room on the right side to have the front brake lever at the right plane....it hits the tach.  I would have to move the throttle out an inch or two to clear, then I would not be able to use my bar end mirrors.
Any Ideas?   I found out about the bar swap here on the forum.
73 CB350F
05 Sportster 883(wifes)
09 Sportster 883
78 Suzuki GS750E
97 Corvette
Offline carnivorous chicken
Re: CB350F with short CB400 bars
« Reply #1 on: May 14, 2018, 06:02:43 PM »
You can likely loosen the banjo bolt on the master cylinder and move that part out of the way with a little rotation.
