Author Topic: 1973 CB500 Four Cylinder head cover leaking  (Read 609 times)
Offline vietng
« on: May 25, 2018, 10:00:03 AM »
Hi all,
I'm a newbie here. Been reading and learning from this forum for a while but 1st time poster.
I have a 73 CB500 (K2) Four which got its motor completely restored about 1.5 years ago. For a while, I have noticed that a cover on the Cylinder head section (please see attached photo) leaks. I can definitely say the issue is getting worse (from the last ride). From your experience, what could be the issue here and do I need to remove the head cover to get it fixed? From reading the manual and part diagram on bikebandit, it could be the gasket around that area but again I am not sure.
Thanks guys.
Offline Scott S
Re: 1973 CB500 Four Cylinder head cover leaking
« Reply #1 on: May 25, 2018, 12:00:24 PM »
 See the two "ears" on either side of that cover? If you remove the screw in the center and pull the cover, you will find two O-rings on those ears. Replace the O-rings.
 There's also an L shaped bracket that bolts to the head...that's where the center screw goes. There's a tiny bit of adjustment on it. Make sure the "ears" are getting seated fully.
 Should be a simple fix.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline vietng
« Reply #2 on: May 25, 2018, 09:07:05 PM »
Thanks a lot Scott. I will try it over the next weekend and report :).
Offline Little_Phil
« Reply #3 on: May 26, 2018, 01:07:44 AM »
The other area that can leak (apart from the seal all around the cam cover) is around the little L shaped bracket that Scott mentioned. There is an aluminium (I think) washer under the L bracket. This is to stop oil coming up the shaft of the bolt that holds the bracket in place. If the cam cover has been removed in the past this may have failed. Avoid the temptation to just keep on tightening this bolt as the thread is easy to strip in the head.
Offline vietng
« Reply #4 on: May 26, 2018, 09:19:58 AM »
Thanks Phil. Im ordering the parts and hopefully can attempt the fix next week.
« Reply #5 on: May 26, 2018, 03:46:01 PM »
i use copper washers under those ears,you need one under the bolt head and under the ear,i get copper washers and o rings from a diesel pump and injector repair place,they have all the odd ball stuff.
