Author Topic: Feeling Chuffed - Speedo repaired  (Read 769 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« on: May 06, 2019, 01:25:50 PM »
Somewhere along my recent 4,500km trip around Southern Africa, my speedo packed up. It had been reading about 20kph low according to my GPS and then the needle started bouncing around a bit before settling firmly at 0.
On the road, I checked for the obvious things;  the cable was fine but nothing registered on the clock.
Today I took it apart to see what I could see; getting that ring off is a real effort!
What I discovered is that the gear driven by the cable (which drives another gear, which turns the speed cup and drives another gear or two, finally turning the digits which turns the digits) was spinning on it’s spindle.
Fortunately I had another parts speedo (shown in pics) and was able to swap the part out and all was well. :)
I’d like to say this was the result of a rigorous, systematic diagnostic process, but the reality is, it was more luck than anything else!
And apart form fixing my speedo (hopefully since I haven’t tried it out yet) I learned how the thing works. If you’re interested have a look here: https://www.explainthatstuff.com/how-speedometer-works.html
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Re: Feeling Chuffed - Speedo repaired
« Reply #1 on: May 07, 2019, 01:21:04 AM »
Tested it this morning.
It works :)
But it’s still reading low! :(
And anyone who has taken a speedo apart, or tried to, will understand why I’m going to leave it at that!
« Last Edit: May 07, 2019, 01:22:50 AM by The Lone Builder »
CB450 K1 - Stalled.
« Reply #2 on: May 07, 2019, 11:25:44 AM »
Sure the cable is OK?
« Reply #3 on: July 28, 2019, 02:52:39 AM »
Sorry for long gap.
The cable is relatively new and looks OK.
My newfound joy didn’t last long. The speedo was still readin g low when I checked it with a GPS
Still, it worked and was recording mileage more or less consistent with GPS.
Then needle started bouncing again, and trip and odometer. Started recording much lower readings than GPS. Finally they stopped turning altogether. So now I’m relying on he GPS as both speedo and trip meter.
Looks like I’ll be taking it apart again at some point, or getting a replacement; but not right now!
CB450 K1 - Stalled.
Offline jlh3rd
« Reply #4 on: July 28, 2019, 04:40:17 AM »
thanks for the write up, and article. Did you find an easier method for re- crimping that ring other than what's been published? I re-did a tachometer, but it wasn't fun trying to get that ring on .
« Reply #5 on: July 28, 2019, 05:25:05 AM »
‘Fraid not. And I scratched the case in the process  :-\
CB450 K1 - Stalled.
