Author Topic: Headlight only functional in neutral and when clutch is engaged.  (Read 1479 times)
Offline Kreb
Hey guys,
I just wired up a new headlight on my 76' Cb 550. It looks great but its only lighting up when the bike is in neutral or when the clutch is engaged. I must have wired something up wrong but i'm not sure what it could be. For the headlight I wired in the new socket exactly how the older one was so it is most likely something else thats wrong. Let me know if you have any ideas.
Thanks
Re: Headlight only functional in neutral and when clutch is engaged.
« Reply #1 on: July 05, 2019, 07:15:48 PM »
If stock: the Green-Red wire in the headlight is the Neutral-safety circuit. The headlight is likely using that for its ground, so use a different Green (only) wire for the headlight.
Offline ofreen
« Reply #2 on: July 06, 2019, 09:39:16 AM »
Yes, the headlight is not grounded correctly.
Greg
'75 CB750F
