Author Topic: New to the forum  (Read 1079 times)
Offline Kiwi Dave
New to the forum
« on: June 20, 2019, 07:38:39 PM »
Hi All,
I started on the restoration of an olive green 350 four that I inherited a few months ago. It is very original except for the 4 into 1 pipes. It has been sitting in a shed for 8 years so the carbs were all gummed up so that is the starting point.
So I have found carb kits online with various reports of satisfaction so I decided that it is time to join a forum and ask for / search for recommendations.
I already have a 77 Yamaha RD400C and 71 Ducati 450 Desmo restored, as well as a 75 Kawasaki KT250 awaiting restoration.
Looking forward to being part of the forum
Dave
New Zealand
Offline spotty
Re: New to the forum
« Reply #1 on: June 20, 2019, 08:09:50 PM »
gday from the west island
i blame Terry
Offline rosewood
« Reply #2 on: June 20, 2019, 08:20:24 PM »
Welcome Dave..
If your are in Akl hit me up.. happy to help where I can, I have access to an ultrasonic cleaner if you want to give the carbs a good once over, great for cleaning out pilot jets too...
rosewood...
Offline Kiwi Dave
« Reply #3 on: June 21, 2019, 01:17:57 AM »
Thanks for that, I transit through Auckland airport often but dont stop.
Initially the bike would not start so I pulled the carbs down. Pretty messy inside so a big cleanup and the bike ran but the float bowl overflows all leaked. So I googled rebuild kits but the reviews varied and so I joined this group to see if there was recommendations around float valve replacements. I did see that rubber tipped float valves are best but I cant find them.
Anyway, I'm looking forward to making progress with it
Cheers Dave
Offline Robbo
« Reply #4 on: June 21, 2019, 04:17:22 AM »
Cheers Dave
Dave, before you throw money at it, are the float heights correct?  Might be a simple fix.
1973 CB350 Four, 1975 CB550K
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #5 on: June 23, 2019, 03:11:53 PM »
Welcome from 47 degrees north.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline jaytee-nz
« Reply #6 on: June 24, 2019, 07:18:56 PM »
Hi Dave - JT here from New Plymouth.
Be wary of aftermarket carb kits - they are notorious for being poor replacements for genuine Honda parts.
Brass carb parts rarely wear out so try re-using your originals if possible (float valves do wear out of course).
Cheers.
« Reply #7 on: June 25, 2019, 05:18:15 AM »
Welcome :)
Offline Kiwi Dave
« Reply #8 on: August 30, 2019, 03:03:02 AM »
[/quote]
[/quote]
Thanks Guys for the comments and especially Robbo. Good point abut the float heights.
I think the first thing to do will be to throw some fuel down the inlet line with the float bowl(s) off and check that the float valves cut off the supply when pushed up with a finger. If I get a fuel covered hand then I guess checking the float heights becomes a bit academic.
I see that Brian at http://www.loudfastugly.com/ has carb kits and I was thinking of trying them.
Cheers Dave
Offline tool14
« Reply #9 on: August 30, 2019, 01:40:59 PM »
welcome
