Author Topic: CB750A tranny klinking and klanking  (Read 4404 times)
Offline jukku
  • Happy with my Hondamatic
« on: September 19, 2019, 10:30:20 AM »
Broken vibration damper springs on Honda CB750A Hondamatic.
Noice from the tranny when gear is engaged.
https://1drv.ms/v/s!AvgjL1lJG5iElNhh70pL3R76VM2Eew?e=QtLZQ7
Offline vik351
  • Adelaide South Australia ...
Re: CB750A tranny klinking and klanking
« Reply #2 on: September 19, 2019, 09:30:08 PM »
didnt sound too good, be buggered if I woulda ran it that long with that noise...
How much of a fun job replacing those springs...???
Ya will replace them all at the same time I presume...???
I only get my bikes next week so then I can have a listen to them...  :'(
vik...goodluck...
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #3 on: September 20, 2019, 04:27:05 AM »
Thanks for sharing the video and the repair. My A makes a similar noise, but is worse in neutral. It goes away in gear. Was a complets disassembly  necessary to replace the springs ?
.....Paul
Offline sammon287
« Reply #4 on: September 20, 2019, 10:27:36 AM »
.....Paul
Mine was similar to yours. I didn't know these springs breaking was a thing until I took everything apart and found them in pieces. Unfortunately, it does require a complete engine/transmission tear down to get to them. I'm replacing all plain bearings and seals. I'm reusing transmission ball bearings, the clutch disks, and the primary chain guides. One of the primary chain guides is very expensive and the other is unobtainable. They look OK, so I'm hoping they don't disintegrate after my long and expensive rebuild. I'm also hoping the replacement damper springs hold up better.
1976 CB750A
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #5 on: September 20, 2019, 10:28:08 AM »
Some noises are only the result of carbs not synced well and/or idle speed set too low.
Mine had exactly this issue, and no noise since.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline ORAZIO
« Reply #6 on: March 24, 2020, 03:39:42 PM »
Broken springs.
My solution to avoid that some pieces of springs go between the gears.
I inserted a 6.35 mm section of Oring in the springs in order to retain any broken rings.
20200121-124615" border="0
20200221-174955" border="0
« Last Edit: March 24, 2020, 03:41:44 PM by ORAZIO »
« Reply #7 on: March 27, 2020, 05:54:45 PM »
 They all break.......no matter what they are used for. Street, dragracing etc etc etc. They all break.....every time.
« Reply #8 on: March 28, 2020, 01:22:14 AM »
What more can cause vibrations on a CB750A?
Bike vibrates a lot when riding from around 50 mph and rising.
Problems holding the handle bar.
No specific noise at idle.
These springs replaced. Converter replaced too. Same vibrations.
A friend has a CB750A -77 (Japanese stickers) in mint condition he has tried to figure out what cause these vibrations.
« Last Edit: September 05, 2020, 09:26:16 PM by PeWe »
Offline vik351
« Reply #9 on: March 28, 2020, 04:02:18 AM »
I had a K2 back in the 70's and this is my first mike since then, 40 odd years, I recokn my 750A has more vibes that I can remember from the K2, but just in the frame, not the bars.
The K2 had bad speed wobbles but that was right up there 70-80 mph
??? weird one... good luck, ask on the main forum perhaps...???
vik...
Offline Bazzer
« Reply #10 on: September 04, 2020, 08:56:37 AM »
Hi, could you tell me where you got the springs from for the repair that you have done. I have my crankcase split, and notice the springs on mine were broken. Hope you can help.
        Baz.
Offline sammon287
« Reply #11 on: September 05, 2020, 06:19:23 PM »
        Baz.
Ebay.
https://www.ebay.com/itm/Honda-750-Input-Shaft-23110-393-010-23110-393-020-23110-393-030-Springs-CB750A/331671472951
1976 CB750A
« Reply #12 on: September 05, 2020, 09:28:11 PM »
My friend plan to take the CB750A to a dyno and let it run to verify if it is engine with rear end related.
Offline TdLpps
« Reply #13 on: October 09, 2020, 10:51:02 AM »
So.....what's the fix?  Based on your knowledge of the 'A' bike you have to have tried a few different things.
I've heard of sold rubber dampers being used but with no other info than that -- no part numbers, suppliers, etc.  Is there a stronger spring or one with more space between coils that will more likely avoid coil bind which seems to be why these break.
Do you know if the drag bikes approach the damper unit differently?
Thanks.
Offline jukku
« Reply #14 on: October 09, 2020, 01:19:57 PM »
One moore season ended with broken springs and same noise as 2019 season, not more or less.
Offline TdLpps
« Reply #15 on: October 09, 2020, 01:31:14 PM »
So, just to clarify....you replaced the spring set with the DME springs and the noise went away.  Then, by the end of the 2019 riding season, the noise returned and the new springs were broken?
Offline jukku
« Reply #16 on: October 10, 2020, 12:59:03 PM »
Oh no. Theese broken springs are the original. I'm sure that all springs have been broken at least two seasons probably three.
Winter 2018-2019 I put the ignition timing, valve clearance and carbs on spot and it reduced the noice. Now it is clincking a little, specially as cold, only in neutral and in gear unloaded. Going to change the springs and do a top end job during the winter.
I still have 2 sets jtmarks new springs on the shelf in my workshop. ;)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #17 on: October 10, 2020, 01:54:16 PM »
Sync your carbs too
